focus rs ABS problem
Old Aug 20, 2007 | 11:12 PM
focuschivvy's Avatar
focuschivvy
Default focus rs ABS problem
the ABS light wont go off
i know i posted this in general discussion too but i really need to find out for mot purposes
bled all the brakes.....twice
the only thing that i can think of now is that after the crash the drivers side abs lead got sheared in two by the calliper.....got a new one, wired it up but the lights still on
would the brain need re-setting because its registered a fault in the past? like it does if the airbag goes off?
cheers, andy
Old Aug 22, 2007 | 11:40 AM
justin2's Avatar
justin2
yes mate brain does need resetting but if you take off battery lead for about 15 mins that sometimes clears it and its all ok then but doesnt always work but defo worth a try ok!
Old Aug 22, 2007 | 01:21 PM
steve7786's Avatar
steve7786
I've got a similar problem with mine with the traction control light on. I have swapped the faulty part but the light is still illuminated.
I have tried the hard reset method by disconnecting the battery, so i'm now left with booking it in to Frauds @ £70 plus VAT to get it on their machine.
Have you checked that your ABS sensor is sat flush and connected up firmly?
I'd try disconnecting the battery for 20 mins first and see what happens from there. Make sure you know your radio code before you do it though.
Steve
Old Aug 22, 2007 | 02:03 PM
justin2's Avatar
justin2
hi guys on some of the older focuses i know that you can sometimes do an ecu reset also by putting the ignition on an off 3 or 4 times in quick succession you should here a bing if this has happened this may also help to sort your problem without the aid of paying for it to be reset!
best of luck guys hope it saves you paying out!
Old Aug 22, 2007 | 02:59 PM
steve7786's Avatar
steve7786
Isn't the bing when you do that to do with encoding the remote keys to the car?
Old Aug 22, 2007 | 03:45 PM
chrisTDCI's Avatar
chrisTDCI
I had a similar problem a little whilst ago, it turned out one of the earth points to the right of the battery was loose.
Old Aug 22, 2007 | 03:54 PM
justin2's Avatar
justin2
yes mate i think so but it also does a partial reset of ecu from what i aware of.
Old Aug 22, 2007 | 04:28 PM
focuschivvy
cheers guys ill hae a good butchers tonight
Old Aug 22, 2007 | 06:44 PM
steve7786's Avatar
steve7786
Good luck with it, let me know how it goes. I think a trip to frauds is in order for me as i've checked just about everything
Old Aug 22, 2007 | 10:23 PM
focuschivvy
.... tried all i cound but nothing, earths, loose connections, unplugged the battery for 20 mins, checked everything was all nice and tight but nothing
looks like an ecu remap!
cheers anyway guys!
Old Aug 24, 2007 | 08:30 AM
steve7786's Avatar
steve7786
Have you had either of the drive shafts pulled out recently?
This is a relpy i had to my post on another forum
'hi mate i had both my drive shafts changed and when i got car back the abs /esp light was on so i pulled the boss, and he said yeah we noticed that so they stuck comp on and it was sayin o/s wheel sensor so they wanted 150 quid off me 4 new sensor.. i took the risk and bought a abs sensor from scrap yard 4 £20 bingo the light went off and not been back on'
Could be worth having a look to see if the sensors are sat in the hubs correctly.
I'm popping in to Fords tomorrow so i'll let you know how i get on.
Old Aug 25, 2007 | 04:40 PM
steve7786's Avatar
steve7786
Well after a trip to Ford my problems has been fixed (fingers crossed ) I had the car on the IDS machine and ran through a few things, it doesn't like Omex and had a few fault codes come up because of that.
Having tried to clear the DTC's the light was still on, it turned out that the steering wheel angle sensor has to the calibrated by turning the steering wheel through a few angles whilst running the tests through the IDS.
Since doing that the light hasn't returned in over 100 miles and comes on and goes off with the ESP switch.
Old Sep 5, 2007 | 10:22 PM
phill295's Avatar
phill295
id say the normal action is to get you codes read and then rest the place i work at charge £40 to read and rest codes you dont need to take it to fords and get charged £70 plus vat for the same job lol
focuschivvy
i would not get you ecu remap just for a abs warning light try reading codes first hope it helps
original
Apr 28, 2026 05:20 PM
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
rdvil
Aug 15, 2015 12:11 PM
