MAJOR F***ING PROBLEM
Old Apr 30, 2007 | 06:30 AM
zvhrst's Avatar
zvhrst
Default MAJOR F***ING PROBLEM
right, duno if anybody looked at my post about my melted motrocraft spark plug,..
well eventually got some NGK 'R's and fitted these while at work,
i started it up let it warm up and i live no more than 10 miles away from work,
anyway, sets off home on the bypasses giving it some stick, felt really good, seemed to be pulling extremly well, then DISASTER!!!!!!
just around corner from my house i come out of a junction into 2nd and it comes on boost......... BANG splutter missfire... looks in mirror, blue/grey smoke,
whips plug out after i pulled in yard turns her over, spiting pure oil straight out of number 3 cylinder (this is same cylinder that melted my plug) havent had time to take head off yet but i'm suspecting melted piston with possible cause from faulty injector?
so am not a happy bunny at the min
does anyone agree it could be injector? as i am not sure tbh escort RST's on MFI are my speciality but not all this new technology in ECU's lol,
alao any1 else ever heard of problems like this on FRS?
oh and its std by the way
Old May 1, 2007 | 09:46 AM
monkey nutz's Avatar
monkey nutz
Bloody hell mate, you must really kick the arse out of it! Hope you get it sorted, and it doesn't turn out to be too expensive!
Old May 1, 2007 | 11:06 AM
kmrobertson3's Avatar
kmrobertson3
Same happened to me on a track day at Knockhill, I have jst spent 4K on a complete engine rebuild. Still not 100% sure if it was detonation or an injector or what.
Old May 1, 2007 | 11:10 AM
Lami's Avatar
Lami
What mods you running?
Old May 1, 2007 | 11:28 AM
zvhrst's Avatar
zvhrst
not what i wanted to hear lol
what have you got for 4k? is it tuned alot now?
engine is std aswel lami
ive sorced a company that can over bore my block and fit a liner so i can use std pistons.
Old May 1, 2007 | 11:34 AM
Lami's Avatar
Lami
How old is the car, what mileage, and has it full ford service history???
Old May 1, 2007 | 11:43 AM
zvhrst's Avatar
zvhrst
its a 52 plate 2003 model
its done 46k miles
and totally std,
yes full ford history
Old May 1, 2007 | 11:50 AM
Lami's Avatar
Lami
Well my first port of call would be fords, as its std.
If you get no joy with the dealer (which you wont) then ring ford CC and play
up merry hell, and I mean hell.
Id threaten them with watchdog etc etc, and it will be the last ford you ever buy.
It wouldnt be the first time ive heard of CC at least paying 50% of the cost of
repairing an engine out of warranty.
You have nothing to loose by trying
Just put the std plugs back in, even if one has melted
Old May 1, 2007 | 01:42 PM
LeviA's Avatar
LeviA
My mam had a 91 Escort automatic and the gearbox went after about 30k and 4 years later. She got more than 70 percent from Ford CC. This was in 95 though.
When I had my first FRS it was 15 months old and 8k on it. I complained about the seat bases and was basically told to fuck off. Fair do, I gave the rant about buying Fords for years and how I wouldn't buy one again blah blah. Still I'm back to owning them and still got no joy.
Ach well, it's worth a try though you never know!
Old May 1, 2007 | 01:48 PM
kmrobertson3
Yea, its now low comp new pistons, rods and the head was also ported and polished. Uprated oil pump. My block was bored out also so car is now 2047 cc.
Old May 2, 2007 | 07:58 AM
zvhrst's Avatar
zvhrst
who did this mate as everywhere i have rang says this cannot be done so ive been pricing engines up,
Old May 2, 2007 | 10:30 AM
kmrobertson3
Ian Howell of Area-Six/Fiesta Frenzy 01522 877887. You can only fit a liner in the middle two piston housings if it is the extrnal ones you have damaged I think you will need a new block.
You will probably find that Ian is more competively priced than most other engine builders also.
Tell him Keith sent you.
Old May 2, 2007 | 10:32 AM
bassboy's Avatar
bassboy
Hi mate sorry to hear about your problems...were u driving flat out by any chance? or did u ever have the car flat out for a long period of time?
with regards to boring the engine...of course it can be done! people are feeding u BS as it is essentially the same as any other Zetec engine there is out there...just with beefed up buts and an oil return!
u can bore it out +1mm even 1.5mm IIRC using bigger pistons...
get Ian Howell to supply u with some CP Racing pistons and Eagle steel rods and your away! 2047cc is generally what is achieved with the rod and piston package and the over bore is ever so slight.
HTH if u have any questions give me a shout...worked with Zetecs LOADS including my own ZT...
bassboy
Old May 2, 2007 | 12:02 PM
zvhrst's Avatar
zvhrst
cheers for info will give ian a ring now
Old May 2, 2007 | 02:00 PM
kmrobertson3
Ahh you might have to call him between 5-8pm as this is the best time to get hold of him.
Old May 3, 2007 | 08:28 AM
zvhrst's Avatar
zvhrst
right will do, tried him yest couldnt get thru but will try after 5 today
cheers mate
Old May 26, 2007 | 07:02 PM
tarmac terriost's Avatar
tarmac terriost
i have hear about motorcraft plugs breaking up and go into the engine which causes internal damage to the engine normally piston and block
also have seen this on my m8's supercharged mondy
normally due to the car running lean and heating the plugs up which breaks the tip of the plugs
on all zetecs/rs it seems the number three piston and bore always pop
when headgasket go or other failures like yours
dont know who told that is cant be rebuilt is bs m8
they can be rebuilt but will need to be over bored with over size pistons and upgrade con rods have to go this way as ford dont do pistons only rings the other route is new block or engine from ford
but like the others said speak to ian howell or power engineering or jamie going of jamsport plays with a lot of zetec's
as the rs focus is a black top zetec engine with a turbo attached to it with a few other mods
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
IainRS1700T
Sep 25, 2015 06:44 AM
