Smoking FRS
Wanna be whore...
Smoking FRS
Hi guy,
I've got a problem with my FRS and i was hoping that someone on here would be able to shed some light on it.
Right i took my FRS into Ford for it's 62500K service last week, which all went well, apart from the usual brake pads needing changed! On my way home from the garage i noticed alot of thick white smoke coming from the rear. The car all seems to be running fine, if anything it might be a little down on power but that could be in my head. The smoke only seems to appear at low revs and on pull away. I am planning on taking it back to ford but thought i'd try to get a little ammo before i do.
Thanks in advance
Warren
Thanks in advance
Warren
Wanna be whore...
I've had it all check over now and it is the turbo that's blown I think i know when it went as well. I was pushing my FRS quite hard up a slip road onto a duel carriage way and it started to jerk and pull back a bit then shortly after that i noticed the smoke
oh well, looking on the bright side i'm gonna use this as an excuse to upgrade
Wanna be whore...
Originally Posted by rssteve
what you upgrading too then?
Wanna be whore...
Originally Posted by kmrobertson3
I've done it and it is a really good set up. I would suggest spending extra on propper custom map with dreamscience after your turbo upgrade.
Spec and power graph showing 328 bhp 444Nm torque
Graham Goode Racing K & N air filter induction system.
Graham Goode Racing Sports catalitic convertor.
Superchips Bluefin with sportcat file.
Milltek full cat back exhaust system.
Vibra-Technics rear torque steer reducing bush conversion.
AP Racing big brake upgrade 6 pot calipers and 355mm grooved discs (red calipers) Ferodo DS2500 pads.
EBC blind drilled and grooved rear discs with Redstuff pads.
All Samco coolant, ancillary and boost hoses in red.
Magnacor 8.5mm red spark plug leads.
Primary Designs Inconel manifold.
Primary Designs/Turbo Dynamics GT28/32 roller bearing conversion of the standard turbo.
Creative Carbon carbon fibre front splitter.
Apexi AVCR electronic boost controller.
Possible custom superchips map via Primary Designs.
Wanna be whore...
That's a nice little spec sheet you got there
I've already got Turbo Technics GT25/28? Superchips Bluefin, GGR K&N air filter induction kit. And i'm gonna add Turbo Technics GT25/28? Primary Designs manifold, sports cat and a Radtec Chargecooler.
That should be enough to keep me happy
Steve Escos
01-10-2015 06:57 AM
