ST170 Heatshield
Old Jul 10, 2006 | 03:10 PM
richard_syko's Avatar
richard_syko
Default ST170 Heatshield
My sis keeps compaining of her heat shield rattling on her ST170.
I think she means the exhaust heat shield! Havent had time to look myself, just wondering if its a common problem?
CheeRS
Rich
Old Jul 10, 2006 | 03:52 PM
JamesS2RS's Avatar
JamesS2RS
My friends one does it all the time...
Fords answer to fix it was take it off.
Cheers,
Jim
Old Jul 11, 2006 | 08:48 AM
tsutton's Avatar
tsutton
If it's the CAT heat shield, then see http://www.fordst170.co.uk/known.php - under "Rattle noise form under body while at 2,000rpm"
Old Jul 13, 2006 | 05:54 PM
robby71's Avatar
robby71
my manifold heatshield used to rattle as the bolts holding it on had reacted to the heatshield metal and corroded through.
i tried to remove the bolts to replace them with new ones with washers but the heads rounded off
i've since used some stainless cable ties to fix it at the lower point where 2 other bolts had corroded through next to the downpipes - did the job
Old Jul 13, 2006 | 09:56 PM
tsutton's Avatar
tsutton
That's a great idea... where can we find one from?
Old Jul 13, 2006 | 10:08 PM
robby71's Avatar
robby71
i bought them from here -
http://cgi.ebay.co.uk/ws/eBayISAPI.d..._BIN_Stores_IT
Old Jul 13, 2006 | 10:14 PM
tsutton's Avatar
tsutton
Awesome, thanks! Going to bid.
Old Jul 13, 2006 | 10:18 PM
robby71's Avatar
robby71
yep i used 2 so have 2 spare
on the lower part if you have the holes (bolts corroded through) slide 1 end through each hole and around the downpipes - the ties work like the plastic ones - pull harder to tighten
i took my car to an exhaust fitters to get them to remove the heatshield bolts and was told they'd have to take off the manifold, drill out the bolts and rethread - would have been upto 4 hours labour at £40 p/h - cable ties were a bit cheaper at £2.49 and 5 mins for me to fit
Old Jul 18, 2006 | 08:37 PM
GTechR's Avatar
GTechR
I'd take it off... why hide a such a funky looking exhaust? if heat is a problem then get it wrapped in exhaust wrap
Old Jul 18, 2006 | 08:57 PM
tsutton's Avatar
tsutton
No road ramp or jacking equipments.
My parents house has a tiny hill which "just" give me access to the cat area to use the steel tie wrap to secure it.
With my house purchasing and buying stuff for the house, road ramp & jacking equipments are low priority.
Perhaps in the future...
Old Jul 18, 2006 | 09:25 PM
GTechR's Avatar
GTechR
Bummer... fair play mate, shame you dont live a bit closer, you could have borrowed mi garage!!
Old Jul 18, 2006 | 11:11 PM
robby71's Avatar
robby71
you don't want to leave it off unless you do wrap the manifold - there's too much heat which will melt the power steering pipes, etc
Old Jul 28, 2006 | 09:12 PM
AndyRST's Avatar
AndyRST
Oh the ST170 rattling @ 2000rpm from the cat heatshield. How i miss those nice days where you can drive along with the window open and listen to the rattling as you drive .....
NOT!
Used to annoy the hell out of me when i had my ST170. How ford could expect anyone to drive along in a nearly new car and it rattle worse than a 17yr old Escort is beyond me and one of the reasons i wanted a Focus RS
Old Aug 6, 2006 | 07:54 AM
tsutton's Avatar
tsutton
Now managed to find the time to do it and it was a success!
One month ago
http://www.hypergallery.co.uk/catheatshield/IMG_4505
Today
http://www.hypergallery.co.uk/catheatshield/IMG_5014
The fix
http://www.hypergallery.co.uk/catheatshield/IMG_5016
Many thanks to robby71 for the suggestion!
Old Aug 6, 2006 | 10:16 AM
robby71's Avatar
robby71
excellent - just like mine (i cut off the excess) - not had any rattles since
Old Aug 6, 2006 | 02:43 PM
AndyRST's Avatar
AndyRST
Tony i did the same fix to my ST170 and it would cure it for a while but the metal cable ties would work loose after a few months and i would have to do it again. Became a real pain in the arse doing that every 3 months
Old Aug 6, 2006 | 02:56 PM
robby71's Avatar
robby71
mine were on when i bought the car 4 months ago and are still tight - not sure who fitted them first and when
Old Aug 6, 2006 | 03:37 PM
tsutton's Avatar
tsutton
Well, it's better than paying loads of money.
Old Aug 6, 2006 | 09:43 PM
AndyRST's Avatar
AndyRST
Yeah defo better than paying.
Mine still had both bolts in the heatshield but rattled. IF i still had the car, i would have De-catted it now and ditched the cat and heatshield
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Sp3no
Sep 27, 2015 07:23 PM
Marv888
Sep 26, 2015 03:44 PM
Andypandy260
Sep 23, 2015 10:28 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
