Ford Focus Range This Section Contains All The Ford Focus Model Specific Forums.
mk1 focus 1.6 2 quick questions
Old Jan 27, 2013 | 07:03 PM
Smiffy2k8's Avatar
Smiffy2k8
Default mk1 focus 1.6 2 quick questions
i have a 2000 1.6 hatchback,
i need to replace the drivers side hub, are the 1.4 and 1.6 hubs the same,
and im thinking of replacing the engine for another 1.6 lower milage, mines 142000mile, the swap will be easy enough for me, can you swap the engines without swaping ecus aswel, and does it matter weather the engine is from a hatchback or a saloon, because saloons are easier to find in a 1.6
Old Jan 27, 2013 | 10:04 PM
Smiffy2k8's Avatar
Smiffy2k8
anyone.??
Old Jan 27, 2013 | 10:12 PM
Ben-B's Avatar
Ben-B
Hubs are the same on the petrols AFAIK, only the ST170 hubs are different.
I would imagine that you can keep the same ECU, if you're just swapping engine and no ancilliaries over it shouldn't be too difficult a job, did one myself on a Renault Megane in 1/2 a day, not bad considering I'd never touched a french car before.
Look into it, but might be better trying to get the engine from an Auto... they won't have been revved hard or redlined at all, so might be in better nick.
Old Jan 28, 2013 | 12:11 PM
Smiffy2k8's Avatar
Smiffy2k8
Sound lad, didnt even think about looking for an auto
Any idea about the saloon and hatchback having the engine
Old Jan 28, 2013 | 12:29 PM
Straight_4_N/a's Avatar
Straight_4_N/a
You can use the fron hubs from any 1.4/1.6/1.8
Engine wise just swap the engine over no need to change the ecu..
You can use the engine out of any mk1/1.5 focus or fiesta mk4/5 as long as the engine cover says zetec-se it will work in your car...
Old Jan 28, 2013 | 12:34 PM
Smiffy2k8's Avatar
Smiffy2k8
Aite lad sound, off hunting for a car now
Anutternutter
24
Aug 31, 2015 01:24 PM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
Prickly_buzz
Aug 25, 2015 11:33 AM
Gadget
Ford Escort RS Cosworth
Aug 13, 2015 06:43 AM
Ben26
Aug 11, 2015 04:19 PM
