Ford Focus Range This Section Contains All The Ford Focus Model Specific Forums.
weird boil up
Old Jun 12, 2012 | 07:50 AM
swain78's Avatar
swain78
Default weird boil up
Hi all had to travel to my home town and at about 80 my temp gauge rose to top or normal/red and bounced round to 3/4 and back to red. Keep to 70 and town she stays half way. No water loss. But plenty of air. No rough idle either. Could this be pump stat or pressure cap
Many thanks guys
Old Jun 15, 2012 | 08:36 AM
swain78's Avatar
swain78
Anyone??
Just got back from plymouth to yarmouth. On dash trick looking at the temp. At 70 the temp is between 105-109. Push to 80 hits the high red temp saying 124. Plant throttle count to 5 temp drops to. 115-116 for bit then rises again. Drop speed sits bout 105-108 same as round town.
Changed pressure xap. Heaters not pumping hot air just luke warm. Water bubbling like mad with air. Not convinced on head gasket as not loosing any water and she still goes like shit of shovel with no rough idle or anything associated with leaking head. Wondering if pump is failed
Old Jul 5, 2012 | 05:41 PM
James B's Avatar
James B
Im not a mechanic just gonna suggest maybe the thermostat is knackered?
Old Jul 5, 2012 | 05:52 PM
the_frozen_one's Avatar
the_frozen_one
More than likely the pump, any water coming out the return pipe at idle?
Old Jul 21, 2012 | 02:02 AM
swain78's Avatar
swain78
If return pipe you mean the one from stat housing ti expansion then yeah slightly on idle load as revs oick up
Old Sep 12, 2012 | 05:15 PM
TheSupremeAuthority's Avatar
TheSupremeAuthority
When i had overheating problems on my tddi i changed out the;
-thremostat (overheating went up from 60mph to 70mph)
-Radiator (from 70 to 80)
-cyclinder head temp sensor (overheating sorted, well until the night i killed the engine going to top speed for a few miles)
however it was still boiling and had oil in the header tank, and when i took the old engine out, there was oil in cylinder 3. turned out the pistion ring/head gasket had gone.
I'd suggest changing the Thermostat (£12) first then the cylinder temp sensor (about £30-£34 iirc)
bigryrs
Mar 28, 2016 09:11 PM
bigryrs
Fiesta RS1800/RS Turbo
14
Jan 21, 2016 09:54 PM
muz
Aug 1, 2015 06:48 AM
