Ford Focus Diesel This forum is for discussion of all things pertaining to the Ford Focus Diesel Range.
Focus voltage sensor location
Old Jan 11, 2013 | 01:33 PM
terrya's Avatar
terrya
Default Focus voltage sensor location
Hi,
Ford Focus 2003 1.8 tddi Intercooler.
Engine sometimes splutters and sometimes cuts out, and then will restart after ignition switch cycled. Seems to worse during wet weather (clue?).
Only recent diagnostic messages relate to low battery volts.
However, battery and alternator output are OK whenever I manually measure them. Battery connections, earth points and main fuses & relays all cleaned and vaselined
Where are the voltage sensor and voltage regulator located ?
Thanks in advance for any assistance
Old Jan 11, 2013 | 03:59 PM
oldford's Avatar
oldford
There isn't a voltage sensor. That is measured inside the engine ecu.
If the battery voltage is o.k. but the voltage to the engine ecu is not, I suspect some problem in the connector to the engine ecu, possible water ingress.
Old Jan 11, 2013 | 05:19 PM
terrya's Avatar
terrya
Would that be the ecu within the tddi pump, or the unit near the driver pedal box ?
Old Jan 12, 2013 | 09:11 AM
oldford's Avatar
oldford
Do you have the exact diagnostic messages? Or there numbers?
Old Jan 12, 2013 | 12:58 PM
terrya's Avatar
terrya
Hi,
The message is DTC 9138 = low battery voltage. As I say, the battery and alternator seem OK whenever I measure the volts nso this must be some kind of intermittent event.
Cleared memory a few times, but this message returns after a while.
terrya
Old Jan 12, 2013 | 01:10 PM
oldford's Avatar
oldford
Don't recognize this as an engine fault. I think this is a dashboard fault.
How did you obtain this DTC?
Old Apr 16, 2015 | 07:46 PM
domik100's Avatar
domik100
Got similar problem. battery voltage measured directly is ~13.8V (engine on), regardless off batt. load (lights, defrost etc). But on dash (in test mode) batt. volatge is lower ~13.6V and now the funny part - when i turn on headlight it drops to 12.9-13.0V and engine stalls. I turned on all electrical systems (but no lights) and it was still 13.6V on my dash.
Measuring volts on battery it was at all time 13.8V (headlights on, etc).
Looks like ECU connection problem, but why does it occure just with the headlights on? Current flow is also OK 4.2Amp = ~55W per one bulb.
mondeo 2002 mk3 2.0 petrol
Old Apr 16, 2015 | 09:40 PM
terrya's Avatar
terrya
I think you are on the right track. I believe the voltage sensor/regulator logic is within the ECU.
After my intermittent problems, my ECU failed completely and due to repair costs vs car value, the car went the to scrapyard.
RSBryden
Sep 6, 2015 08:39 PM
gavt123
Sep 5, 2015 10:03 AM
hopper350
Sep 4, 2015 12:53 AM
Sep 3, 2015 10:49 AM
