Ford Focus Diesel This forum is for discussion of all things pertaining to the Ford Focus Diesel Range.
Turbo timer in Focus?
Old Jul 7, 2011 | 03:30 PM
Icekottarinn's Avatar
Icekottarinn
Default Turbo timer in Focus?
Does Focus diesel have turbo timer or similar as std?
Is it important to let the engine run for a while, before turning it off etc...?
Old Jul 7, 2011 | 04:11 PM
RichieST's Avatar
RichieST
If you've been running at high rpm for a period of time then allow it to idle for a minute or two before turning off, otherwise it's fine to switsh off straight away.
Old Jul 7, 2011 | 04:19 PM
Icekottarinn
Ok thanks, so this car have no kind of "Turbo timer" or cooling/lubricating after it is turned off?
- are these turbines/engines strong?
- ahat can I expect to get in totel milage?
Old Jul 7, 2011 | 04:29 PM
martysmartie's Avatar
martysmartie
No not as standard, in any case you don't need a TT, they are more of a gimmick really, best thing is just to stay off boost for the last couple of miles before your destination.
If it's a MK1 (And so the 1.8 engine or 1753CC ) then they go on forever, that engine has been around for a long time, it's the same one as can be found in Escort vans etc, just make sure the cam belts changed though.
Martin
Old Jul 7, 2011 | 04:37 PM
Icekottarinn
Thanks, I have a TDCi 2005 car and the 1,6 engine.
I am told I should shift the time/cam belt every 10 year or 240.000 km, but I will change before that.
It has now done 62.000 miles, and the family is looking forward to the next 100.000
Old Jul 8, 2011 | 01:03 PM
martysmartie
Oh so that's a MK2 then, yes Fords recommendation is 100K or 10 years, whichever comes first, but you would be trusting to adhere to this! Many change much earlier, around 62,000 miles is the general consensus. I think Haynes themselves recommend 45K.
Martin
Old Jul 8, 2011 | 10:29 PM
Icekottarinn
[QUOTE=martysmartie;5533994]Oh so that's a MK2 then, yes Fords recommendation is 100K or 10 years, whichever comes first, but you would be trusting to adhere to this! Many change much earlier, around 62,000 miles is the general consensus. I think Haynes themselves recommend 45K.
Martin[/
Thanks Martin.
I contacted the Ford dealer here in Iceland and they told me 240.000 km or 10 years for cambelt replacement for this diesel engine, have you any other info on this in UK?
- Because this maintanence or replacement is very important as we all know...
sigurjon
Old Aug 19, 2011 | 02:39 AM
macker1380's Avatar
macker1380
Muppet
I also have a Focus tdci 1.6, a 06 model van,
I have been told that it has a timing chain which does not need to be replaced,
is this true?
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
Oct 9, 2015 07:38 PM
Matt Baxter
Sep 16, 2015 08:30 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
