Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
Ford focus 1.6 engine mods
Old Sep 23, 2018 | 11:30 PM
Kelvin j's Avatar
Kelvin j
Default Ford focus 1.6 engine mods
Hi i have a 2009 ford focus 1.6 ztec s its too slow on accleration theres not pull to it what mods are recomended to make the car faster on acceleration
also the car seems high up the rev range like at 70 it sits 1 line over 3000 revs is there anything i could do to it to get better rev range instead of it screaming at higher speed ? Would a 6 speed gear box instead of a 5 do it ?
Old Sep 24, 2018 | 05:21 AM
haz87's Avatar
haz87
Fit a bigger engine - there really is little point spending out on the 1.6.
Change the gearset or wheelsize if you want to manipulate your gear ratios to bring down the revs @ 70. A 6 speed would be a way of doing this, or a diesel box (im not too clued up on focus derv box ratios but "usually" they will give you a taller 5th)
Old Sep 24, 2018 | 05:51 AM
oldford's Avatar
oldford
If you lower the rev range by whatever means, the car will pull even worse.
If you want to make it accelerate faster, you should increase the revs in at least the lower gears.
Old Sep 24, 2018 | 06:50 AM
studabear's Avatar
studabear
Buy a different focus. 2.0 perhaps or even a ST
Old Sep 24, 2018 | 06:48 PM
Kelvin j's Avatar
Kelvin j
Okay thanks all
Old Sep 24, 2018 | 10:29 PM
martysmartie's Avatar
martysmartie
The 1600 (Sigma) is actually quite a good engine, lightweight and responsive.
Can imagine in a MK2 performance can suffer a little, due to being heavier.
The Ecoboost 1600 is based on this engine, so can't imagine it being that hard to turbo charge (you would need to lower the compression) although not the easiest route. Other than that they respond well to cam changes but as always N/A power is expensive power!
I disagree about the gearing though, I find the gearing to be tall, and the engine speed @ that roadspeed I consider to be pretty good.
Martin
Old Sep 25, 2018 | 12:45 AM
Kelvin j's Avatar
Kelvin j
Thanks martin i did look at turbo but can’t find a turno manfold for the 1.6 only find one for the 2L or above i could look at getting a custom made one and lowering the conpression but id need to do a few other bits and bobs to make it be able to take the turbo it may be alot of money but il have a look into that also one pf my mates mentioned getting bigger pistons and boring it to a 1.8 but dont know if i could do that but thats somthing im looking at too but i heard that can be exspensive
Old Dec 29, 2023 | 10:30 AM
Fraz1's Avatar
Fraz1
Remove the 1.6 and replace it with a 2.0 duratec turbo
Old Dec 29, 2023 | 07:08 PM
GVK.'s Avatar
GVK.
Yeah.....
adam.dodd86
Apr 29, 2014 07:38 PM
jelly-monster
Ford Focus Range
Nov 22, 2012 02:32 PM
dave_s2_rst
Nov 14, 2010 12:22 PM
McGoo 69
Ford Focus RS
15
Nov 9, 2008 03:53 PM
