overheating
Old Jan 24, 2006 | 07:48 AM
PlyTurbo's Avatar
PlyTurbo
Default overheating
hi i have a 1989 rs and its overheating just had the headgasket sorted and still over heating anyidea? im lost could the block be cracked or maybe a air lock water pump?had it for a year or so and first problem ive had
thanks plym
Old Jan 24, 2006 | 11:56 AM
S1 Barkham's Avatar
S1 Barkham
I reckon it just needs the ignition timing and the fuel setting up. Get it down to your nearest tuners and have it set up. Had the same problem with mine once i had sorted my head gasket.
Old Jan 24, 2006 | 01:39 PM
martinmace's Avatar
martinmace
could be air locked mate or it could very well be a cracked block leave the car to idle with the header cap off and the blowers on full blast on hot until the cooling fans come on. this should get rid of any air locks it may have. is the cooling fan working??also did you have the head pressure tested or skimmed before you put it back on??replace thermostat as it could be fucked??some tips for ya mate .how hot is it getting and how long does it take to get hot??
Old Jan 26, 2006 | 11:29 PM
yzfr1boy's Avatar
yzfr1boy
i had this prob turned out to be a crack in block behind turbo have alook there mate
Old Jan 27, 2006 | 03:53 PM
Ben26's Avatar
Ben26
could be something simple like the fans not kicking in like martinmace said .
Thermostat could be suck as well
Ben
Old Jan 27, 2006 | 05:42 PM
JayRS2000's Avatar
JayRS2000
Ben
hello strnager lol on ere now? hows the cabbie ?
Old Jan 27, 2006 | 08:32 PM
PlyTurbo's Avatar
PlyTurbo
did that cause the overheating ??? its a nitemare lol seems to cut in fin the fan i really dunno lol anyhelp would be good cheers
Old Jan 28, 2006 | 08:28 AM
Ben26's Avatar
Ben26
hello Jay, did not know u came on here .
Please say matey is pickin up ya car.
If not are u going to put it back on e-bay ?
Ben
Old Jan 28, 2006 | 08:51 AM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
Are you sure the car is overheating?
What I mean is are the rad pipes getting REALLY hot, is the header tank bubbling up? It may be that the water temp sensor in the head got damaged and is giving a high reading. It might be worth getting a new sensor for the sake of Ł12.
Old Jan 28, 2006 | 08:53 AM
Ben26's Avatar
Ben26
very good point
Ben
Old Jan 30, 2006 | 07:15 AM
JayRS2000's Avatar
JayRS2000
lol car still ant sold mate lol 5th time lucky ???
3 lads ant turned up its shit mate best offer was 700squid
Old Jan 30, 2006 | 10:00 AM
Ben26's Avatar
Ben26
W4nkers
Ben
Old Jan 30, 2006 | 05:47 PM
JayRS2000's Avatar
JayRS2000
in it ebay sucks lol
Old Jan 31, 2006 | 09:15 AM
PlyTurbo's Avatar
PlyTurbo
yep it will make the water bubble like mad when the cars running and the needle slowly rises and just keeps moving up in to red then i obvisly turn it off to stop more damage the fan cuts in bout half way but still doesnt stop it overheating, has anyone else had this problem and when i turn it off bubbles up and water sprays out the headertank even with the cap on ?????????
im puzzled
Old Jan 31, 2006 | 02:29 PM
JayRS2000's Avatar
JayRS2000
sound like u got my luck mate
markeh
Ford Focus Diesel
Apr 11, 2016 02:15 PM
Ade
Feb 8, 2007 05:11 PM
kurdt5
Jul 17, 2006 03:01 PM
fiestaturbo1984
Feb 19, 2006 03:51 PM
woodz77
13
Nov 6, 2005 03:02 PM
