CVH water pump
Old 03-01-2006 | 06:06 PM
creedy's Avatar
creedy
Default CVH water pump
does it realy matter wot way the cam belt goes around the water pump and tensioner?
after fitting a belt i relised i put it on the wrong way around the water pump, but realy cant see any differnce either way it goes.
Old 03-01-2006 | 06:10 PM
Micky's Avatar
Micky
Okay Im not 100% sure BUT
1.I'd refit it the CORRECT way because if the belt jumps off any pulley the head will get 8 bent valve's += BIG repair bill for you!!
2 The pump may turn the wrong way with the belt on wrong and you could get overheating problems.
So if I wqas you I'd refit the belt on correrctly.Regards Micky
Old 03-01-2006 | 06:20 PM
Oranoco's Avatar
Oranoco
As Micky says remove and refit correctly cos you'll feel a proper plank if the engine goes pop as a result of it being on incorrectly.
Old 03-01-2006 | 08:01 PM
creedy's Avatar
creedy
yeah very true guys. will refit it correctly this time.
was just being a numty last time
01-11-2015 06:53 PM
DAZZER
30-09-2015 08:43 PM
20/20 vision
29-09-2015 11:27 AM
Quick Reply: CVH water pump
