oil light
Old 02-01-2006 | 07:18 PM
jonnyfrst's Avatar
jonnyfrst
Default oil light
i was sitting 2 nite for about 5 mins and the oil light started 2 flash but once i started 2 drive again it was fine
but once i stopped and was just sitting there it started 2 flash again
can anyone put some light on this for me
Old 02-01-2006 | 07:21 PM
stusfesta's Avatar
stusfesta
check ya oil level mate
320 bhp's Avatar
320 bhp
could be dodgy oil pressure or oil pump on its way out
Old 02-01-2006 | 07:25 PM
jonnyfrst's Avatar
jonnyfrst
i have a oil pressure gage and it used 2 sit at 20psi when i was sitting about but now im lucky if it sits at 10psi
Old 02-01-2006 | 07:32 PM
320 bhp's Avatar
320 bhp
was ment 2 say dodgy oil pressure switch
Old 02-01-2006 | 07:39 PM
jonnyfrst's Avatar
jonnyfrst
i was thinking about the oil pump was on its way out
Old 02-01-2006 | 07:48 PM
320 bhp's Avatar
320 bhp
i had 1 come on once turned out to be the pressure switch but if the pressure on ya gauge has droped would change ya pump b4 it fooks the full engine
Old 02-01-2006 | 07:50 PM
jonnyfrst's Avatar
jonnyfrst
where could i get a new one from mate as im not even going 2 touch a 2nd hand one
Old 02-01-2006 | 07:53 PM
320 bhp's Avatar
320 bhp
any motor factors could order ya 1 but i alway use gen ford pumps look in fast ford mag et plenty dealers in there woodford garage motorsport do a gen ford oil pump for£104
Old 02-01-2006 | 07:54 PM
jonnyfrst's Avatar
jonnyfrst
cheers mate
Old 02-01-2006 | 07:59 PM
320 bhp's Avatar
320 bhp
pleasure mate just dont drive it any more and u mite be lucky and not damaged out else
Old 02-01-2006 | 11:19 PM
fawdy's Avatar
fawdy
good advice
Old 03-01-2006 | 12:51 PM
jonnyfrst's Avatar
jonnyfrst
ok i have checked all wires and there all on
also checked the oil and there is just over max on there
so i really dont know what is wrong with it
would it make any differants if the car was sitting on a bit off a hill and was sitting running on idle with most off the oil sitting at the front off the engine
Old 03-01-2006 | 01:14 PM
320 bhp's Avatar
320 bhp
oil pump mate get it changed asap or u will be forking out for a full rebuild
Old 03-01-2006 | 01:20 PM
jonnyfrst's Avatar
jonnyfrst
not a full rebuild again lol
i will need 2 get one asap and get it sorted
Old 03-01-2006 | 01:35 PM
andysrs's Avatar
andysrs
Default dont drive it
This is what mine was doing, it now needs a rebuild,thought was a dodgy oil pressure switch obviously wasnt.
Old 03-01-2006 | 01:36 PM
jonnyfrst's Avatar
jonnyfrst
ah well here goes for a full rebuild then lol ah well never mind
Old 03-01-2006 | 01:42 PM
320 bhp's Avatar
320 bhp
just change oil pump mate easy job bottom pulley of sump of you can et straight at it u mite lucky and get away with just changing it DONT USE THE CAR ANYMORE
Old 03-01-2006 | 01:52 PM
andysrs's Avatar
andysrs
Default as above
as above like 320 bhp said!! dont make the costly mistake i did, now sounds like a tranny diesel
Old 03-01-2006 | 01:55 PM
jonnyfrst's Avatar
jonnyfrst
cool looks like it will be sitting for another week till i get the parts for it lol
Old 03-01-2006 | 02:54 PM
jonnyfrst's Avatar
jonnyfrst
should i do a zvh or zetec turbo converion as im having so much trouble with the engien and car or leave it and jus tkeep sorting every little bit that goes wrong
Old 03-01-2006 | 03:16 PM
320 bhp's Avatar
320 bhp
i just built a zvh and they cost a fortune if i was u and ya happy with ya current spec engine keep it every 1 has teething probs with em mate there old cars now dont let it get to u get a new pump and go from there
Old 03-01-2006 | 03:19 PM
jonnyfrst's Avatar
jonnyfrst
cool i will just keep on going with the car and see where i end up but i mite just get it running and sell it as i also think the guy that sold me it knew all this was going 2 happen and wanted rid off it asap
Old 03-01-2006 | 03:59 PM
JamboRS's Avatar
JamboRS
focus rs 1672
bit of advice the max line is there because thats the maximum you can fill it too,it doesn't have to be on the max all the time,you usualy find theres a litre between min and max,goin over the max does not make it run any better and can do damage to an engine,get a proper oil gauge on there and check that its makin the right pressure at cold start up,warm and 2k revs
other than that its take oil pump out and check for wear,i ate 2 oil pumps coz i put a powder coated rocker on my car and it was still all swarf on the inside,which was bein flushed round my oil pump,after 2 oil pumps ate it was then a full bottom end rebuild as it eventually wore the bores,so a bit costly for a nice rocker cover
Old 03-01-2006 | 04:05 PM
jonnyfrst's Avatar
jonnyfrst
its just over the max as the car is on a hill as i cant get it in the driveway but its ok i mite have the car sold the way it is if not then i will sort the pump and oile change and see how that goes
Old 03-01-2006 | 06:22 PM
jonnyfrst's Avatar
jonnyfrst
car now sold
yatta
21-05-2016 10:31 PM
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
cozzzzy power
04-09-2015 08:14 AM
hopper350
04-09-2015 12:53 AM
turbowag
03-09-2015 08:07 AM
Quick Reply: oil light
