Dawes devices basic boost controller
Old Sep 15, 2005 | 08:06 AM
Rallyesport's Avatar
Rallyesport
Default Dawes devices basic boost controller
I have ordered one of these as I'm tired of the amal slowing down the boost build up. This will give faster maximum boost and it's adjustable. It's not a conventional bleed valve.
http://www.dawesdevices.com/basic.html
Old Sep 15, 2005 | 08:35 AM
addiction's Avatar
addiction
why dont you just remove the Amal valve?
Old Sep 15, 2005 | 08:59 AM
Rallyesport
That's what I'm going to do. After I've removed the amal this boost controller will be installed between the pressure outlet on the turbo and the actuator.
Old Sep 15, 2005 | 11:54 AM
addiction's Avatar
addiction
i used to run one on my rst and couldnt really notice any difference!! the guys at Interpro Automotive took it off when i had it set up because of boost spiking!!!!
Old Sep 15, 2005 | 02:31 PM
JesseT's Avatar
JesseT
I built something like this and it's been fine:
http://speedracer90.tripod.com/mbc/
Old Sep 15, 2005 | 03:02 PM
Rallyesport
Did you run a Daws devices boost controller? What did they put on instead?
Old Sep 15, 2005 | 04:00 PM
addiction's Avatar
addiction
yes it was and they didnt put anything else on at the time. i run a lockable bleed valve now,which keeps the boost at a constant 14psi when on full boost. just disconnect the amal valve and dont worry bout it! do you use a -31 actuator?
Old Sep 15, 2005 | 04:06 PM
Rallyesport
Yes.
Old Sep 15, 2005 | 04:41 PM
AKRS1's Avatar
AKRS1
i ordered one from ebay similar to this and the bloody thing takes plenty of time to adjust. you have to loosen the nut adjust it and then retighten the nut and to be honest i didnt find any difference at all. Yours might be different though be interesting to see if you notice a difference
Old Sep 15, 2005 | 08:41 PM
Rick's Avatar
Rick
It all depends what u want to acheive. My setup has zero spike. At the mo, it hits 26psi and holds it. It's basically an in car valve, with feed taken from crossover on a -34.
I will be changin it, as i want to spike 34 ish and then hold 28, but we'll see.
Old Sep 19, 2005 | 07:28 PM
rs shawn's Avatar
rs shawn
S1 Database Editor
Was it fitted correctly? The dawes device STOPS spiking.
The Basic Boost Controller holds the signal from the wastegate until it reaches the level that you have set. Because of its rapid actuation, "spiking" (momentarily exceeding the boost limit) is almost completely eliminated. If you already have a boost gauge installed, you will notice that your "factory" boost level will sometimes overshoot the intended peak (or "spike") and then settle back to a sustained level. Our controller is much less susceptible to these boost spikes, allowing you to use the full boost level programmed into your ECU. By using our boost controller, you may set the sustained boost to the level that the factory control used to spike to.
A mate had one fitted to his Scooby turbut & said it was a lot smoother driving & holding boost than before it was fitted.
Old Sep 19, 2005 | 08:58 PM
Rallyesport
It uses the same concept as Turbo XS High Perfomance Boost Controller and Turbosmart's boost controller which both costs three or four times as much.
Old Sep 19, 2005 | 09:10 PM
cuvner's Avatar
cuvner
i had one didnt notice a difference, gd thing is it only will bleed enough for 1bar thats its max, although u may want more!
JUst thought if you got a decent -31 or -34 actuator then you wont get much waste gate creep!
Old Sep 19, 2005 | 11:07 PM
addiction's Avatar
addiction
Yes it was fitted correctly dont believe everything you read!!. has one of these things EVER been reccomended to you by a professional tuner?
Old Sep 20, 2005 | 07:15 AM
rs shawn's Avatar
rs shawn
S1 Database Editor
Well Lane
gets ready for the replies of Well Lane aren't professionals....
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
DAZZER
Sep 30, 2015 08:43 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Russ Payne
Sep 25, 2015 08:29 PM
