fookin help me
fookin help me
no spark???s1 turbo taken to garage had new dizzy plugs leads d,cap coil blokes had it two weeks what else could it be ????????????/ could it be that esc 2 thingy ?soz i dont know much about cars really read escort manual only thing i can see is that esc 2 could it be that
I know this probably doesn't help much but i had the same trouble with mine last year, changed everything and still no spark ended up pulling the whole lot out in the end and putting efi management in only thing i didn't try at the time though was the esc2 unit so could possably be your problem
Ontop of the Dizzy there is a cheap and weak plastic connection.Check that for breaks as it 'may' be a distributer fault..?
There is a small wire in there that is prone to letting go,im not sure if that can be replaced or youd need the whold dizzy unit though
ecu is on the bluck head, silver one, some on ebay, normally about 20 quid max unchipped
check the small green wires from the coil, they run down the cross member outside the loom and back up the driverside inner wing, check there are no breaks in it,
apples24
26-06-2004 09:03 AM
