Running Rough!
Old Jun 23, 2004 | 08:18 PM
Gav90spec's Avatar
Gav90spec
Default Running Rough!
Hey, wondering if any1 can help, I've got a S2 which is standard apart from chip. I've recently re-built engine and fitted new turbo and radiator. When starting it will wind and wind and eventually offer a few times and then after about 2 mins will finally start( and yeah I've tried disconnecting cold start). When started I've to keep revs up til warm or will cut out. Seems awful misfirey and when driving it just splutters. It runs to hot aswell(just below red). Im not convinced my coolant is bled?? Also the oil pressure light came on a few times, but only when accelerating. Can the fuelling effect the temp the car runs at?? I was thinking fuel pump relay or fuel ecu?????Also the exhaust downpipe flange is not sealing very well at turbo. Any help wud be appreciated. Cheers Gav.
Old Jun 23, 2004 | 08:31 PM
jodyhoare's Avatar
jodyhoare
sounds fucked, but u say u rebuilt it? did u do the head gasket properly?? and timin also firein order!!
Old Jun 23, 2004 | 08:34 PM
Gav90spec's Avatar
Gav90spec
Yip, im a mechanic to trade, but when it comes to Rs Turbos its a different story The head gasket was done proper and the firing order is pro.
Old Jun 23, 2004 | 08:35 PM
KSA-Cossie's Avatar
KSA-Cossie
Timing could be out,oil pressureswitch could be fooked,thermostat could be fooked and fan switch/fan.
Old Jun 23, 2004 | 08:37 PM
Gav90spec's Avatar
Gav90spec
Also I read on a post that the cold start valve has a blue connector, i always thought it was brown/tan colour?? Are they idiot proof because im sure I put the brown one on to it?
Old Jun 23, 2004 | 08:40 PM
Gav90spec's Avatar
Gav90spec
Yeah , could be oil press switch. New thermostat fitted and fan switch ok. I was thinking more air locks in coolant system. Wasn't sure the best way of bleeding them?
Old Jun 23, 2004 | 08:41 PM
KSA-Cossie's Avatar
KSA-Cossie
they are colour coded m8,blue is cold start can't remember what the brown and yellow one's are
Old Jun 23, 2004 | 08:43 PM
KSA-Cossie's Avatar
KSA-Cossie
i was told to take the pipe off the top of the thermostat housing to bleed the cooling system.
Old Jun 23, 2004 | 08:54 PM
jodyhoare's Avatar
jodyhoare
like he says m8 the connectors are idot prof, just connect colour to colour, but as i said b4 check the timin, ur oil pressure could be ur oil return pipe bein blocked!!
Old Jun 24, 2004 | 09:54 PM
Alan s1's Avatar
Alan s1
ive got a very semailer problem with my s1 it runs shity untill she's warmed up its just been rebuilt so im going to hae the fueling looked at and see
Old Jun 25, 2004 | 05:11 PM
Gav90spec's Avatar
Gav90spec
Yip, im going 2 set the 'Co' at work tomorrow, hopefully I get sum improvements. I really need 2 get it set up.
Old Jun 26, 2004 | 11:16 PM
Alan s1's Avatar
Alan s1
check for air leaks as well m8 mines got a small one and its runnig rough but does need setting up on the rollers
TPM961
Jan 15, 2018 10:50 AM
xrmalin
Sep 13, 2015 06:52 PM
BRAM
Sep 8, 2015 07:11 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
Rizlablue
Sep 6, 2015 09:58 AM
