Alternator charging question....
Just checked the battery on my bros RS Turbo.
It was charging at 11volts - 11.2volts when idling.
When turned off the battery was holding a charge of 11.5volts.
I know Vauxhalls require the battery light on the dash to be working otherwise the alternator wont charge, is this the same with RS Turbos? as the battery light on the dash doesnt light up at all.
Any ideas why its not charging or holding its charge?
Cheers, Addz.
![Rolling Eyes](https://passionford.com/forum/images/smilies/icon_rolleyes.gif)
Cheers, Addz.
Yes this is the same its part of the charge circuit!!! Check theres voltage coming from the blue wire off the alternator if not check the bulb (should come on anyhow with the ignition) no voltage alternators fooked i'm on my 3rd in a year
Connect the voltmeter to the negative battery terminal and to the blue wire on the alternator?
hi
your volt readings are to low, your battery should read (without the engine running roughly 12.7volts and with the engine running it should be above that eg @6000rpm 13.5volts or there abouts
that blue wire which goes from the alty to the battery light is an earth to put the light on when the engine is not turning (its earthed via the alty). once the engine is running and the altys charging, that blue wire goes from a earth to a live (due to the alternator charging)which puts your light out.(12v + 12v = no light) if the buld goes or that blue breaks it will still charge. This is alot simplier charging system to the vauxhall one
its the red wires which go from the alty to the starter then the battery are the important ones
check it at the back of the alternator (the red wires) with a multi meter if your not getting over 12volts your altys fooked.
try it and lets as know
As above, no light no charge.
To test the bulb and circuit down to the alternator, the easiest way is to short the blue wire to earth with the ignition on (engine doesn't need to be running). The bulb should light up. If it does, alternator is fucked. If it doesn't then you need to know if there is 12v (ignition on) on the end of the wire (disconnected from alternator). If there isn't then pop the clocks out and check the bulb. If it's blown ,replace, if not, check there is 12v (ignition on) at one side of the bulb on the printed circuit and also on the blue wire coming off the back of the clocks.
if the bulb goes or that blue breaks it will still charge.
Originally Posted by DazC
If there is no battery light then it is not meant to charge....
you can throw the bulb away and it with charge (as long as the alty ok that is)
just try it or look at the wiring diagram
the light on this system is a tell tail only and not part of the charging circuit
this is a very basic charging system
ps cheers gavintwopies
jonfoc
16
11-09-2018 05:35 PM
Cos500
16-09-2015 09:50 PM
