abs removal.....how easy and wot do u do?
Old 02-05-2005, 10:03 PM
cossie_wona_b
cossie_wona_b's Avatar
Default abs removal.....how easy and wot do u do?
how easy is it to remove abs on a s2????
Old 03-05-2005, 04:31 PM
turbo.jon
turbo.jon's Avatar
easy get all lines&fluid resivour from a mk 4 escort without abs or just rip it all out get some pipe made up to go from servo ends to the 3 way valves in each inner wing. or just cut the belts ive just used all bits from a diff car as with other 1s the rear end can lock up easy but its up to u
jon
Old 03-05-2005, 07:56 PM
cossie_wona_b
if i cut the belts wont the brake pedal be rock hard tho???
Old 03-05-2005, 08:28 PM
adamS2RST
adamS2RST's Avatar
Im getting mine fully removed soon, i have rear discs, now im worried back end is guna lock up
Old 03-05-2005, 09:28 PM
BODGE
BODGE's Avatar
adam i've had a few with rear disc's now and you really have to slam on for the rear to lock up
as for the ABS rip out all the pumps, brackets, and brake lines, then make up 2 new line to go from the master cylinder to each T on the inner wings, you will need an XR3I res bottle
mark
Old 03-05-2005, 09:32 PM
adamS2RST
adamS2RST's Avatar
Mark, thanks for that.
I have also been told you can use original res bottle by linking the pipes between the ports?
Old 03-05-2005, 09:40 PM
cossie_wona_b
you are all legends in your own rights!!
im gona use a 3i bottle,n speak nicely2 a m8 who just happens to b breaking a early rs2 n nab da brake pipes and thats a fookin result boyz!!
Old 03-05-2005, 11:05 PM
bud-weis
Football Cwazy
bud-weis's Avatar
i used some mondeo brake pressure reducing valves ( you can just see them in the pic on my master cylinder. i have rear discs and they locked up very easily !! not anymore though . ( fiesta rs turbo by the way, i removed the abs completely, including the compensators on the back and replaced the master cylinder and all lines )
tankybaby66
06-02-2016 02:24 PM
muzzman1
30-09-2015 08:59 PM
Quick Reply: abs removal.....how easy and wot do u do?
