ecu problem????
Old Apr 27, 2005 | 05:23 PM
cooler king's Avatar
cooler king
Default ecu problem????
the car has been into the tuners for the past couple of days theres not much more they can do with it until the ecu gets sorted out!!!!!!! aparently the engine isnt communicating with the ecu correctly, on closer inspection the ecu has 'blown'. that would be why its a bitch to start and keep running till warm!!!!!!!!!!!! just wondering, hes told me over the phone i need a 0280800196 ke 2.6 ecu????? any ideas where to get one of these from fairly cheap?
also how easy is it to change the injector seals and manifold gasket? they are in need of replacing aswell so i want to get hold of them before the weekend and possibly do it over the weekend to get it somewhere near!!!!!!!!!!!!!
Old Apr 27, 2005 | 08:45 PM
NUTS RuS's Avatar
NUTS RuS
If the ecu had blown I guess it wouldn't run at all ....... ??
Seals and gasket should take 2 hours max ( thats with a lunch hour in the middle too )
Old Apr 27, 2005 | 09:42 PM
glenis's Avatar
glenis
pmsl
Old Apr 27, 2005 | 09:54 PM
DazC's Avatar
DazC
That sounds like the Bosch fuel ECU which will still allow it to run (as the spark is controlled by the ESC 2 silver ECU) but won't control the fueling correctly....
I assume this is on an S2?
cooler king
he he he!!!! should be ok then!!!!!
apparently it will run, eventually with with no ecus???????
Old Apr 27, 2005 | 10:09 PM
NUTS RuS's Avatar
NUTS RuS
Daz I was just thinking if its blown how can it control fuel at all ?
Old Apr 27, 2005 | 10:29 PM
DazC's Avatar
DazC
If it's an S2 the basic fueling control is mechanical but enrichment for on boost and warm up is electronic...controlled by a seperate ECU.
The ESC 2 Ford ECU is a glorified ignition module with spark maps and boost control intergrated. All it does is comunicate breifly with the Bosch ECU (which controls fueling) on pin 25 and 20.
Old Apr 27, 2005 | 10:37 PM
GrimmeRS2K's Avatar
GrimmeRS2K
its a pity somebody cant do more with the fuel ecu
Old Apr 27, 2005 | 10:53 PM
NUTS RuS's Avatar
NUTS RuS
and were all guessing what car it is..... suppose the section its posted in is a clue - but you never know
Old Apr 28, 2005 | 05:22 AM
cooler king
yeah it is the s2!!!!
he said that the engiune doesnt rwalise that its cold due to thios ecu problem! thats why it coughs and splutte4rs and doesnt want tostaystarted!!!!! :-(
Old Apr 28, 2005 | 10:00 AM
db's Avatar
db
This really sounds like a management problem.
The KE-Jetronic always injects extra petrol when the starter motor is turning, warm or cold engine.
Directly after the engine runs, mixture is enriched for a fixed period, warm or cold engine.
Then the system detects the engine temperature en from this fact the mixture is enriched until it is 60 C.
It is unlikely that all of this is broken at the same time in the KE-Jetronic, so a (temporary, just to check) swap of the Bosch computer would maybe solve the problem.
Old May 4, 2005 | 03:36 PM
davidreader5's Avatar
davidreader5
HI,
SURE the ecu number is not 0280800194, check it yourself i have 4, here and all
have the same number, written on the front of the ecu,( black one)
Dave R.
DixieTheKid
11
Jun 6, 2020 11:20 AM
DixieTheKid
Sep 14, 2015 09:04 PM
Tank Mike
Sep 14, 2015 03:56 PM
tib2220
Sep 14, 2015 12:33 PM
dms04
Sep 11, 2015 01:57 PM
