Car popping and backfiring
Old 23-04-2005 | 11:32 PM
glenis's Avatar
glenis
Default Car popping and backfiring
What causes a ERST running EFi to pop and sometimes even back fire when pulling away from a standstill ?
it seems to only do it when warmed up, or sitting a traffic lights etc... not when cold...
as i lift the clutch and go to pull away normally, it hesitates and judders, and you can hear the exhaust pop occasionally or if really bad it backfires ?
is this due to leads arc-ing with each other, or a worn rotor arm and dizzy cap ?
its fu*king annoying, everytime i am in town, it kangaroos from a standstill
Old 23-04-2005 | 11:53 PM
ON-UJAH's Avatar
ON-UJAH
What EFI are you running? Most modern systems will no longer have a rotor arm or dizzy.
The reason is most likely to be a too rich mixtue - the causes of this could be almost anything, from a warn cam lobe, to dodgy injector, wrong plug gap,bad set up...it could even be a sticking or leaking valve. Best to get it checked over by a pro - with the EFI there's not much you can do at home.
Old 23-04-2005 | 11:55 PM
glenis's Avatar
glenis
efi from a FRST
its a 2.1 zvh.... running L8 cosworth management...
someone said the TPS, could that be it ?
Old 24-04-2005 | 12:00 AM
ON-UJAH's Avatar
ON-UJAH
Right so it's the EFI injection manifold, but running Cosworth management? Who mapped it? What injectors? I don't think anyone here will be able to provide you with an answer - best go back to the tuner that installed the system and get them to take a look. Any sensor which is either no longer working or not properly calibrated or compatible with the system could cause such problems. It could even be a fault in the ECU itself.
Old 24-04-2005 | 12:02 AM
glenis's Avatar
glenis
yes cosworth management L8 from 4x4 sapphire...
green injectors (803 ?)...
ony had the car 1 month, didnt seem to do it when first got it...
any ideas on the TPS, just put brand new plugs in it (PP8s) and genuine leads
Old 24-04-2005 | 12:10 AM
ON-UJAH's Avatar
ON-UJAH
Wrong plug gap? You could swap the TPS easily enough so it's worth a try.
Old 24-04-2005 | 12:19 AM
glenis's Avatar
glenis
yeah someone just said the exact same thing, it could be wrong plug gap
something as simple as that
the plugs are ment for a big turbo escort cosworth, so i bet the gap is incorrect for an RS turbo ZVH, so i need to re-gap them
Old 24-04-2005 | 01:21 AM
glenis's Avatar
glenis
where can i find out how to correctly gap my motorcraft AGPR12 PP8 spark plugs ?
thanks
Old 27-04-2005 | 02:54 PM
glenis's Avatar
glenis
would a phase sensor covered in oil cause this problem ?
took the dizzy apart, and saw the phase sensor switch/plug was saturated in oil...
rotor arm and cap were fine.... just wet through phase sensor etc....
Billy_RS
15
05-09-2015 01:04 PM
Shows & Track Days
26-08-2015 06:11 AM
blakey100
04-08-2015 09:17 PM
sjssms
02-08-2015 08:01 PM
CabrioTurbo
01-08-2015 12:04 PM
Quick Reply: Car popping and backfiring
