Any Solution for the meelting Coolant Sensor??
Hy Guys.
Does any body have a solution for the meelting Water Temp. Sensor near the exhaust manifold?.
Thanks
Thanks
Can't say i've ever cooked one. Do you have a standard manifold or custom. If custom is it overly close to that corner of the head? You could use some heat sleeve over the wire and top end of the sender - that should be enough tbh.
the strut brace
10-07-2005 08:20 PM
turbinator
14-09-2004 08:21 AM
