here we go again.. hot S2.. problem maybe solved?
I've been told, that if you have a problem wit your RST running hot, you should change the thermostat and the thermo timeswiths to those from a cossie????
can some conferm this??
yeh ive done this as i have a grs up front the cossie stat opens at 82 i think and the standard one at 88..
mine still runs hot....and i found out the fans are the wrong way so its sucking hot air though the rad to the front
my rst is at the moment fairly standard but id like to uprate the cooling before i do much more to the engine, whats the best way for me to do this and for me to be able to use myself!?
rs_daz: nice one mate..... LOOOOL
vroooom ptssssh: my old header cap was leaking... so now im waiting for a bailey headertank I think I will buy a XR2 fan switch tomorrow.. sounds very good.... tanx mate
Sounds really silly but I think really important. I had this problem when I was running a GRS. do you know what I needed to do. Change the Rad. I thought mine was ok but I bought a new one and never had another problem.
i have similar probs, my rst gets hot real quick in town, sometimes even gettin up to the 'n' of norm. then she takes ages to cool down when i start driving at 30 mph. on the other hand, i took her for the 1st time on the m1 and the temp gauge was REAL low, it was literally 1mm below the very first marking on the gauge
i have changed the fan switch for a new one (wasnt cutting in till near top of gauge) but it hasnt helped a great deal , cuts in a lil earlier but not a lot.... this xr2 one sounds good, may have to invest lol1
it would be low on the m1 bcos your blasting it down the motorway so you would get cool air into your engine bay. Fan dont usually come on when your driving down the motorway. Ideally your fan should come on when the temperature guage is on half
Originally Posted by glenis
get a COSWORTH 4x4 FAN SWITCH THEN !!
ITS RED NOT ORANGE
ITS RED NOT ORANGE
problem solved then
if its running more than half way on the gauge u have a problem somewhere, unless u have a grs i/c that is!.
ive got a grs, low temp thermostat, heat wrap everywhere,water wetter in coolant and mine never goes above the half way mark with twin fans
DavidK
27-09-2015 02:55 PM
Russ Payne
25-09-2015 08:29 PM
