Ford Orion EFI…makes things easier to turbo/Zetec?
Hi everyone…
Its been MANY years since I have posted in this section of the forum but I have the urge to buy something Ford again as a run about and have been offered a Ford Orion EFI cheap.
Obviously it requires some work, however, in the longevity of the vehicle, it will possibly end up turbo charged with either a 1600cvh turbo or a Zetec turbo.
What I want to know, is it has an EFI system in there which looks the same as the a Fiesta turbo inlet etc…Does this make turbo-ing it any more easier? Would I be able to go down say EFI Turbo route easily? Also does it mean I could potentially use the 1600 engine in there to turbo (Steel rods, proper pistons, headwork etc)?
Does anyone know what ECU would actually be in the car?
Its a G reg 1.6 Ghia model if that is of any help
Thanks guys!
Thanks guys!
Cheers pal, but my question was more aimed at will this Orion be running OFAB/OFAC management or some other EFI derivative if there is one? And if its the same, essentially, can I use the same engine but bolt on all the turbo bits (rods, pistons, exhaust manifold, injectors etc) from a Fiesta/Escort RS Turbo
Pm Rogeyboy, he'll be able to help you... I'm pretty sure he's running Efi fiesta turbo stuff with a modded Orion loom...
1AFA
Good advice, listen to it
Lee
