Spot light fitting
If your using Ford brackets, from memory, there are two pre drilled holes in the front panel, behind the top bar of the bumper, to fit the upright part of the bracket and backplate. Not a big fan of them, so took them off all of my 5 Mk4's I had, sure they were all the same?
Sorry, no pics, not had an RST for 15 years...
Yep, holes in the panel already there. Just need the brackets and bolts and you're away. Difficult to see, but the holes are on the black painted part on the inside of the lights that runs from the slam panel behind the bumper.
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
