what next step engine modif
Old Sep 30, 2014 | 09:21 PM
luxembourgrst's Avatar
luxembourgrst
Default what next step engine modif
hy her is my spec
still MFI:
piper cam 285 t
group a coil
mongoose exhaust
big airtec intercooler
stage 2 turbo (set to 17 psi)
turbosystem chip (max 18psi)
ingnition advance 16 degree
have 190-200 hp normaly
next step im thinking about stage 3 burton big valve head ?? good idea?
a uprated clutch ?? wich one ?AP organic?? ( is there not one clutch wihtout changing pedal box? )
andim looking about a stage 1 cts gearbox or (ib5 with rst lsd ) good idea?
thanks
Old Sep 30, 2014 | 09:45 PM
Billy_RS's Avatar
Billy_RS
Head work would probably be the next step.
What Pistons and rods do you have as they will need upgrading if your planning on going for big power!
Old Oct 1, 2014 | 07:05 AM
tlr_rst's Avatar
tlr_rst
i thought the degree would be lower if the engine is running more more power etc, not 16 etc, my car is bog standard and it was setup with 13 degree.
i might be totally wrong just threads I've read and picked up on, don't shout at me though lol
Old Oct 1, 2014 | 01:57 PM
russ rs's Avatar
russ rs
Call cylinder head developments
He will post and polish head etc don't go for bigger valves not needed. That work u be lucking under Ł200
Old Oct 1, 2014 | 03:18 PM
Karlos G's Avatar
Karlos G
Balls Deep!
A stage 3 T3 would be your next upgrade for more BHP if your MFI can cope, around 240bhp is the limit of the rods though so be careful, even less if you bounce around the limiter a lot, many have broken them sub 200bhp!
Old Oct 1, 2014 | 05:57 PM
luxembourgrst
ok thanks well stil have tandad piston and standard rods
well ok next step cylinder head stage 3 from burton..
what about the clutch ap organic? is there not an other one without changing the pedal box
Old Oct 2, 2014 | 05:14 PM
Red_bull's Avatar
Red_bull
You haven't set up your ignition timing with detonation detection yet did you? I would go for max advance of ignition. You need detonation detection and on rollers would be the easiest. If you never done it you need help -> Tuner
Old Oct 2, 2014 | 06:02 PM
russ rs's Avatar
russ rs
Originally Posted by luxembourgrst
ok thanks well stil have tandad piston and standard rods well ok next step cylinder head stage 3 from burton.. what about the clutch ap organic? is there not an other one without changing the pedal box
You don't need Stage three head! If anything it will make it worse to drive 😂
Old Oct 2, 2014 | 06:54 PM
Karlos G's Avatar
Karlos G
Balls Deep!
As said, a stage 3 head is pointless at your power.
Old Oct 2, 2014 | 07:18 PM
luxembourgrst
sorry my English but pointless what this mean?
a stage 3 head big valve is it to mutch for my setup will I not win some bhp wih it?
Old Oct 2, 2014 | 09:41 PM
Billy_RS's Avatar
Billy_RS
Pointless = waste of time for your spec
You only need ported and polished head for good gains.
Then add a hybrid T3 Turbo (Stage 3)
200bhp+ easily
Then Mfi and internals are holding you back
Old Oct 3, 2014 | 09:25 PM
HaggisTurbo's Avatar
HaggisTurbo
I would convert to EFI and get some better management make it much easier to tune as well. Stage 3 T3 also a good start
Old Oct 4, 2014 | 08:41 AM
luxembourgrst
pff my stage 2 t3 is brand new hmmmmm
well what about the clutch?
Old Oct 4, 2014 | 10:42 AM
luxembourgrst
but why a satge 3 turbo? because my stage 2 can go up to 20psi
but I only run it a t 17-18 psi because my turbosstem chip limit to 18psi
a stage 3 can go up to 25 psi (like burton says)
thanks guys
Old Oct 4, 2014 | 08:30 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Not needed.
No you will not gain some bhp.
Yes you will need a clutch if you have more bhp.
thanks guys
Stage 3 turbo will make more bhp at the same boost...... 18psi stage 2 turbo around 190bhp, 18psi stage 3 turbo around 230bhp.
Old Oct 5, 2014 | 07:19 AM
luxembourgrst
well ok
if I good understand next step will only be a stage 3 turbo to win some bhp
thanks
Old Oct 5, 2014 | 06:49 PM
luxembourgrst
I just bought a knock detontation LED alert monitor gonna instal it
Old Oct 5, 2014 | 07:05 PM
studabear's Avatar
studabear
efi conversion,
you might just be able to change the exhaust housing on the turbo to a .48
Old Oct 5, 2014 | 07:12 PM
luxembourgrst
Originally Posted by studabear
efi conversion,
you mean on the stage 2 changing the exhaust housing
Old Oct 5, 2014 | 09:16 PM
studabear's Avatar
studabear
Yes as to my knowledge the stage 2 has a .36 exhaust housing.
My stage 2 did on my cvh, I swapped to a .48 for my zetec turbo.
Old Oct 6, 2014 | 08:19 PM
luxembourgrst
it s mean my stage 2 turbo with a 48 exhaust housing is like a stage 3
Old Oct 6, 2014 | 08:46 PM
luxembourgrst
Stock .36/45 will do 190bhp, stage 2 .36/50 will do 230bhp, stage 3 .48/55 will do 300bhp
maybe not a good idea with the 48 housing because the 50 will be 48/50 ??? is it good
mk22door
49
Mar 26, 2022 07:15 AM
skypeller
Sep 19, 2015 09:58 PM
paceo
Aug 27, 2015 12:45 PM
Rickyrustyfox
Aug 13, 2015 01:11 PM
mpilk
Aug 12, 2015 09:40 PM
