Bleed valve?
You will get more boost, BUT the fueling needs to be matched to the increase in boost.
Once this is done don't be tempted to give it that little bit more boost as thats when things go wrong. (imo of course)
If you do fit one you want a decent lockable bleed valve.
I have one fitted but it will be removed once I get around to sorting the boost control on my ecu.
and a cvh that doesn't have an air or oil leak is like finding life in space = none existent
