s2 seatbelt fitting, help
Hi all, need a bit of help with my front seatbelts.
Does anyone know which of the 2 bolts pictured are used with the spacer thing pictured to fit to the b pillar?
![Name: IMAG0871_zps4baeccvj.jpg
Size: 56.5 KB](https://passionford.com/forum/attachments/ford-escort-rs-turbo/72316d1501459842-s2-seatbelt-fitting-help-imag0871_zps4baeccvj.jpg)
When I fitted the rears I used the smaller bolt pictured to bolt to the c pillar ( all seemed nice and tight ), now when I've come to fit the fronts to the b pillar, the longer bolts seems way to long, it sticks out, so the belt has a lot of play on the pillar. I also tried swapping bolts and there is a lot of play in both ( although the longer bolt fits in to the plastic shim in the rear belts fine )
Any help / pics appreciated
track.focus'd
12-08-2015 05:53 PM
