IB5 and S2 LSD????
Looking for a yes or no really, am I right in saying that the S2 LSD fit's straight into the IB5 box?????
Got a spare IB5 box and spare diff sat in the garage so thought I'd chuck the two together for my cabby turbo.
Ginger
Ginger
It does bolt straight in as long as it's the 8 bolt hole mounting to the crown wheel out of a series two.
Make sure you use the crown wheel out of the ib5 & bolt your LSD to that & build your box back up.
I've built one ib5 out of an escort Gti which is going to go in my car and I'm going to be doing another one out of a puma for a friend in the next few weeks.
Yer it's an 8 bolt S2 diff
I haven't got the box apart yet, but from memory the diff sit in a recess in the crown wheel yer!!! how much has to come off the diff mate???
Cheers for the other reply's
Ginger
Ginger
different ib5s use different size parts. ie 1.7 puma ib5 uses bigger thicker items than the say 1.25 fiesta ib5.
So its down to which ib5 your going to fit the erst s2 diff into.
Mine was out of an escort Gti which dropped straight in but my mates got a ka box for me to put his diff in so I may have to give that a fettle
Also check the inside of the crown wheel before you bolt the diff to it as mine had a slight burr on the inside which I didn't spot straight out & it was causing the diff to pick up ever so slightly & not sit quiet square.
TPM961
15-01-2018 10:50 AM
155lee
24-10-2015 11:11 AM
