Rear Disc Brackets??
Balls Deep!
If your fitting them for improved braking then instead spend your money on some decent front brakes, fitting rear discs without big brakes up front means in an emergency stop situation the back locks up first like pulling the handbrake!
Even with decent front brakes they mostly still lock up first.
If your fitting them for looks then be sure to use a bias valve and turn them down.
what percentage of front to rear on the bias valve is recommended? I've left mine at 50% as i've not drove the car since finishing the resto..... Would 10% at the rear be about right?
Whilst the cars apart im gona get it all changed over as im re-doing all the brake lines etc, I am going to run a bias valve to the rear...and eventually upgrading the fronts!
was gonna swap the rears on my orion to discs but was told some scary stories about unbalanced and spinning.just upgraded fronts to 300mm with braided lines all round.its spot on
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
03-11-2015 04:08 PM
