problem on rebuild engine
Old Jul 4, 2013 | 09:28 PM
luxembourgrst's Avatar
luxembourgrst
Default problem on rebuild engine
well guys i had a big problem today i drove the car on the motorway took an exit an when i putted the gear down my engine stalls goes out OFF i try to start it start hard an don t stay on idle i looked at my AFR and it was on 18 ? ? i drove the car at 18 on AFR but only 2 minutes at than i cut the engine off i looked for some big air leak at the engine bay i didnt found
put the black box off turn the pressure again more up try to start the car it start but the idle goes UP and DOWN again UP and DOWN i played with the CO srew also nothing at idle 18 on AFR
and my brake pedal feel hard harder then before
also on idle when i pump with the brake pedal the idle goes up
strange ? a air leak at the brake servo ?
strange that suddently this happen ?
but also my blake box on the meetering unit was a little wet of fuel on it but the 2 O rings gasket looks ok ....
don t understand
Old Jul 4, 2013 | 09:35 PM
Cosworth Lad's Avatar
Cosworth Lad
try your inlet my mate had this problem inlet seal.
Old Jul 4, 2013 | 09:56 PM
luxembourgrst
because if i turn the nuts of the master cylinder to the servo full clockwiss i hear a big pchhhhh when the engine is running but the idle was stable then i turned the 2 nut a little bit anti clockwiss no pchttttt anymore
but wy does my idle automatic goe up to 1200 rpm then falls again to 700 then again up to 1200 than falls again....
Old Jul 4, 2013 | 09:58 PM
Cosworth Lad
airleak maybe inlet?
Old Jul 4, 2013 | 10:15 PM
botters's Avatar
botters
competant bodger
sounds like the diaphragm in the brake servo has failed causing a massive airleak
Old Jul 4, 2013 | 10:21 PM
luxembourgrst
well i gona try to start the engine with a bolt in the enter of the vacum pipe to the servo only to see if there is a air leak or not
Old Jul 4, 2013 | 10:23 PM
Cosworth Lad
get an airline to your turbo put air through youl find the airleak quike,
Old Jul 6, 2013 | 12:02 PM
luxembourgrst
ok GUYS it was the auxilair valve under the intel manifold is ok now
Old Jul 6, 2013 | 12:04 PM
saman's Avatar
saman
Default servo
change the servo i had the same problem
CLIVE
Oct 2, 2015 12:58 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Dr. Ickxs
Aug 15, 2015 11:34 AM
Zoggon
Aug 10, 2015 10:39 AM
