gearbox has shat itself
having run about 200hp for the past year my gearbox has had enough. its developed a whine in 4th/5th and ive already got another box lined up dirt cheap. I was gonna rebuild this box then swap em over but am I pissing in the wind? what other options are there for a gearbox to cope with 200hp ish. I know its hit n miss but im led to believe an ib5 is marginally better. or will a fresh bc box be ok at my power. and would any one on here be willing to fit it? cheers matt
![](https://passionford.com/forum/images/smilies/roi.gif)
Balls Deep!
![](https://passionford.com/forum/images/smilies/shocked.gif)
Roughly £30-£50 for the van and Ka gearbox's.
Here's a Ka one..
http://www.ebay.co.uk/itm/Ford-KA-96...item2576a261bb
Oh I will have to look again lol
I'm just selling my t34.48 so I can fit a stage 3 t3 and steel rods because I want response over power and with the steel rods I can run high boost like 25psi and I don't have to piss about fabricating anything
I'm defo going same as you for the gearbox
how do u find gear change with puma shifter..got 1 here was thinking of doing it but was put off after hearing stories about it
was gonna us it on ma track car with s2 box(in a frst)but heard it flaps about as no spring in shifter or something like that lol..
was at rsoc at knocky there in and struggled all day finding gears with ma old standard linkage so deffo need to sort something out..
got one of those rally design ones coming for it...u reckon its worth keeping that for ma s2 and using puma linkage on fez ?
1/4 mile beasty!!!!
How come you use the ka box aswell when I built my ib5 box I used a mk6 non turbo diesel van box and put my quaife diff it it I had great ratios?
Would the IB5 be strong enough for a 1.8 Zetec on ITBs etc puttting out around 190bhp on track?
Just thinking, being NA there wouldn't be as much torque as a turbo
Balls Deep!
My old IB5 in the Cabby has been running 250-300bhp for the last two years and hasn't broken, that's using launch control and flat shift with real hard driving... But, that doesn't mean they will all take that sort of abuse.
Ka/RST Ratios.
Can't really say mate, they are still a weak box at the end of the day, just not as weak as the old BC...
aslong as it has a very good clutch and linkage set up should be fine, but another thing to concider is the bc/ib5 box doesnt like to change gear anything above 7500prm
chowfornow
14
05-01-2019 09:01 PM
paceo
25-09-2015 08:05 PM
