boost help
Old Jun 11, 2013 | 06:16 PM
Gem frst's Avatar
Gem frst
Default boost help
ive got a fiesta turbo on ofac with a t3 on a bleed valve its wound right in but still seems to be boosting at a bar been told its the actuator ? any ideas
Old Jun 11, 2013 | 06:23 PM
DixieTheKid's Avatar
DixieTheKid
Pick-up P100 Power!
Has i got an amal valve?
Old Jun 11, 2013 | 06:33 PM
Gem frst's Avatar
Gem frst
no it hasnt
Old Jun 11, 2013 | 06:36 PM
DixieTheKid
Pick-up P100 Power!
That would suggest to me either vacuum pipe or actuator. Is the valve plumbed in correctly?
Old Jun 11, 2013 | 06:38 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Sounds like to much pre-load on the actuator, wind it OUT a few turns to see if boost lowers.
If not, pipe the turbo direct to the actuator (removing the bleed valve) and see what it makes, might be a leaking bleed valve.
Old Jun 11, 2013 | 06:41 PM
Gem frst's Avatar
Gem frst
vacum pipe ? i belive its plumbed in thanks will try that karlos
Old Jun 11, 2013 | 07:20 PM
Karlos G's Avatar
Karlos G
Balls Deep!
I think he means if the 'vacuum' pipe that goes from turbo to bleed valve or bleed valve to actuator is split it will be bleeding off air all the time.
Old Jun 11, 2013 | 07:26 PM
DixieTheKid
Pick-up P100 Power!
Thats the ticket, I've once seen a DIY bleed valve plumbed into a Y piece between the plenum and the dump valve or dump valve and ecu, one or the other
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
