Turbo whining
Can anyone help. My s2 escort rst, recently had head gasket changed, now I'm getting a whining sound on turbo when foot is down on accelerator, it's really struggling to move, does anyone have any suggestions.
It pulls away fine but Is slow, I've checked all boost pies and they seem fine to me. The car has been standing for 8 months and just got it back in the road. I'll be honest I am new to this stuff as this is my first rst. When you put your foot down I can hear whining from the front of the car assuming its the turbo and can feel it pulling back if you know what I mean.
Had mot today and passed so brakes are fine, when took boost hoses of I did look at turbine and moves left to right ever so slightly but didn't check if it spins freely.
Balls Deep!
Moving left to right slightly is normal but it does need to spin so just double check it mate.
Also pressure test the intake system, that will show any leaks just in case you've missed something when you looked over your boost pipes, although generally with MFI if a boost hose is leaking it will not idle.
Checked the turbo today and it spins freely, I have noticed I slight oil leak which I believe is coming from the turbo, would it have anything to do with the timing, might have to take it to a specialist, but the timing in the engine is fine
Now your talking a foreign language, it's pulls away fine in first gear but when in second through to 5th you have to drive it like a normal car as something is holding back the power. I appreciate your help though thank you. Like I said this is my first rst.
Mfi will have the KE-jetronic fuel distributor to the right of the engine, with pipes going to turbo and fuel lines to injectors.
Efi system will have efi written on the inlet manifold, i'm guessing that your RS will be MFi
Lost me now, I know there are pipes going to the injectors from bit where the air filter is if that makes sense you prob sound thick but I'm learning with this as this is my first rst, I'll check the inlet manifold tomorrow to see if anything is written on it.
hi u say pulls away in 1st ok does it make a noise when u in 1st or does it only start when u change up to 2nd !! is it a high pitch whine with a essence of rattel ! if it does it maybe gear box bearings !!
There is no rattling, it definitely feels as if the turbo is struggling, I think it needs to be set up as the car has been standing for 8months and I have only just got it back on the road since Saturday, the car was fine before I took of the road, I changed the head gasket as didn't know the history of the car and ever since I'm getting this problem now.
Balls Deep!
ACT - Air charge temperature, monitors the temperature of the air entering the engine, if this sensor is faulty it can cause retarded ignition timing on boost.
Knock sensor, monitors the engine for signs of detonation (fuel/air igniting when it shouldn't) and will also cause retarded ignition timing on boost.
Retarded timing will mean very little power, but as I said above it will not make the turbo whine so probably not that anyway?!
Thank you for the info, I say whining, took it out again today it defiantly sounds if turbo is struggling for power which what you say could be the ecu, I don't understand as when I took it off the road it was fine, done the head gasket and now not running properly, I've now booked her in at a specialist on Saturday, if it is a faulty ECU can they be repaired or would it be a new one do you reckon.
I hope it's not the turbo, wouldn't it whine though when the car is idling, I'm sure when I bought it the bloke had just had it all put it but who knows. I'll find out saturday. Lets hope it's one of the cheaper options, but i have found a few places that can recondition turbos.
Ok cool, it's a g reg 89 I believe, where I've done the head gasket my self if I've connect leads to the wrong place (not HT leads) could this have an effect? I'm 90% sure I have put everything back where it came from.
Surely if the turbo was cooked it would smoke it's tits off
Sounds like the timing is massively restarded, or someone's turned the boost up without having the correct chip
I would personally take it too a specialist before you blow it up and have it checked over
JK12
33
26-04-2021 12:09 PM
