Help please
Old May 28, 2013 | 09:24 AM
conwaysrs26's Avatar
conwaysrs26
Default Help please
Hey I've just recently bought an 88 spec Rs turbo series 2 my first ever proper Rs and I think that the bottom end has grown a slight engine knock it only appears to be in first and second gear really strange. How hard is it to change the bottom end to a 2.1 Zetec and do I have modify the head on the original 1.6 head. What engine do I use for this conversion. Thanks
Old May 28, 2013 | 09:39 AM
DixieTheKid's Avatar
DixieTheKid
Pick-up P100 Power!
If its only in 1st and 2nd it will probably just be the box. The CVH bottom end can take some serious punishment.
I went through about 5 boxes in the time i had me S2.
Old May 28, 2013 | 09:47 AM
conwaysrs26
it defo sounds more like a knock than a whine first n second it sounds like a diesel knock only had it a weak :-( thats why im thinking bottom end. is it a long process the 2.1 bottom end? do i have to strip the whole engine out or can i do it all through the sump or do i have to change head gasket and do head work to ?
Old May 28, 2013 | 10:00 AM
DixieTheKid
Pick-up P100 Power!
Follow this Linky and scroll down. Step by step instruction.
Better of going zetec turbo IMO. They is a link fir that too on the same site
Old May 28, 2013 | 10:14 AM
conwaysrs26
thank you helped alot looks like a fun project to do and not too difficult when i learn how to post pics i will do many thanks
Old May 28, 2013 | 10:17 AM
DixieTheKid
Pick-up P100 Power!
If you go down that route, take my advise and change the box too. MTX75 or diesel BC with slipper depending on the power output.
Old May 28, 2013 | 10:41 AM
conwaysrs26
What car do those boxes come out of ? Mtx75 ?
Old May 28, 2013 | 10:45 AM
DixieTheKid
Pick-up P100 Power!
Most larger CC engined escort, focus and mondeo.
Old May 28, 2013 | 10:49 AM
rsmark86's Avatar
rsmark86
Or get a mk6 escort box and fit newer ka duratec internals and rst slipper, karlos g is using this spec at 300bhp with no issues
And no fabrication needed to fit in our cars, just swap the gearbox bolts about till the mount lines up
Old May 28, 2013 | 10:51 AM
conwaysrs26
so escort mk6 gearbox any model ? ford ka gears and escort rst slipper?
Old May 28, 2013 | 10:52 AM
conwaysrs26
sorry for the questions first time im going to do somthing like this and getting excited ha
Old May 28, 2013 | 10:54 AM
DixieTheKid
Pick-up P100 Power!
2wd RS2k or gti i think. Its been to long.
Old May 28, 2013 | 11:14 AM
conwaysrs26
ok cool thanks. can i ask why the hell people use ford ka internals pmsl
