Difference in the S1 & S2 cvh CRANK
Old 15-03-2013 | 03:31 PM
Danster76's Avatar
Danster76
Default Difference in the S1 & S2 cvh CRANK
Can someone tell me EXACTLY what the difference is between a S1 & S2 cvh crank so i can identify which one is which.
Many thanks
Old 15-03-2013 | 04:11 PM
the_frozen_one's Avatar
the_frozen_one
S1 has a cog drive for the oil pump. S2 has 2 flats.
Have an s2 crank if you need
Old 15-03-2013 | 05:06 PM
Danster76's Avatar
Danster76
Thanks.
I will keep that in mind.
I need an S1 crank now as just heard mines bent so if anyone reading has one kicking about get in touch.
Old 15-03-2013 | 07:12 PM
DazC's Avatar
DazC
They look near identical at a glance but if you put them side by side, the S2 crank has a longer oil pump drive (both have the 2 flats).
Old 15-03-2013 | 07:23 PM
Danster76's Avatar
Danster76
Thanks Daz
Old 15-03-2013 | 08:19 PM
mgtkr1's Avatar
mgtkr1
are they interchangable with appropiate pumps?
Old 15-03-2013 | 08:25 PM
Danster76's Avatar
Danster76
Between blocks? Yes they are.
Old 20-03-2013 | 10:16 PM
turbotrev's Avatar
turbotrev
You bent it!!???
Cheers Paul
Old 20-03-2013 | 10:59 PM
Danster76's Avatar
Danster76
Yes, a 30 thou curvature approx 0.75mm surprised me when I was told.
mk3ste
17-10-2021 10:09 AM
wowk
30-03-2021 07:49 PM
07-10-2015 12:56 PM
Daniel Howard
Ford Classics & Vintage
03-10-2015 10:44 PM
SMILER258
28-09-2015 09:04 AM
Quick Reply: Difference in the S1 & S2 cvh CRANK
