megasquirt 1.6 turbo software settings questions (topic renamed)
Hello,
Does somebody has a 1.6 turbo EFI mapping for me to start with. I'm running standard rs turbo lay out, lets say a fiesta engine
I'm running a MS 2 on the extra code. I'm running without edis unit and modified my MS for running wasted spark with direct coil control.
I'm using the std VR sensor of the fiesta and running a 36-1 flywheel i believe (it's the standard)
I'm also running on a 190 cc/min @ 3bar injectors
But i was looking for a VE table and ignition table on safe side just to start up with. VE table should be exchangeable for all EFI 1.6 with standard equipment
I'm not looking to copy somebody's work, but wanna do my own haha
Another question
What are the dwell times for the original coils? I'm running the fiesta. Is that a zetec coil pack? I found the following:
Generally settings are between 2.0 and 4.0mS, a Ford Zetec coil pack, for example, is 3.6mS running and 6.0mS cranking. The cranking dwell is usually a lot higher than running dwell. 6.0mS seems to be a very good starting point for this. Minimum discharge period (MS1-Extra) is usually 0.1mS - 0.5mS, I always leave this on 0.1mS and have had no issues. Acceleration compensation should usually be set to around 1mS, Maximum Spark duration can be set to 0.7mS (MS2-Extra or PnP)
On the extra code website is find this:
Maximum Spark Duration (ms) (max_spk_dur) is the amount of time MS2-Extra, MegaSquirt-II (or MicroSquirt) tries to wait before starting another charging cycle. MS-II tries to fit the dwell time + max. spark duration into the time between sparks. If it can fit them, then the full dwell time is used. If the time is too short (because the rpm is high) to fit both the dwell and the max.spark duration, then both are shortened proportionally.
If the max spark duration is too long, however, then the actual dwell value gets shortened at a lower rpm, limiting the spark energy at higher rpms. Typical values are between 1.5 and 2.0 milliseconds.
I have now the 6.0ms for cranking; 10 degrees advance on cranking; maximum dwell of 3.1 (to start on the lower side of the numbers i found); Accleration i put on the found number, 1; Maximum spark duration at 1.5 now as i would say it is the save side. But if the maximum spark duration is too short can this mean my coil can't uncharge completly and with a new cycle my dwell times can become too long? no right?
Is the 10 degrees cranking advance good enough for cranking btw?
190 cc/min injectors? Those are extremely low flow injectors.
100% duty cycle and 0.65 BSFC shows those injectors good for only 111 HP.
What boost level are you aiming for?
But i got the injectors in stages control. So two fuelling for 1 cylinder. So then i come too 380cc/min and then it would be good enough for about 180-200 bhp
What inlet manifold are you using? Did you modify a manifold for 2 injectors per cylinder?
Love to see a picture of the inlet - I have never seen a dual injector inlet for a cvh.
Great rebuild of the Escort - looks fantastic!
Your max dwell setting can be pushed upto 3.6ms. Discharge time of 0.1. You should also be using standard dwell not fixed etc.
These settings are fine for normal zetec coil packs. You can use an oscilloscope to set this up perfectly if you like.
Rob,
edit Maximum spark duration can be between 0.5 and 1ms. It is usually much much less this is just the maximum set in code.
Rob,
Are you guys running something different then the standard then?
[img]http://www.megamanual.com/v22manual/extwir.gif[\img]
Two injectors are running to one signal?
Maybe i'm wrong on my flow, but the car isn't close to me and i just took it up after leaving everything for over a year. So might need to double check if you guys say i'm on a low flow.
![](http://www.megamanual.com/v22manual/extwir.gif)
Rob,
Rob,
Anyway the injector problem is probably a mistake on my side as i bought a upgrade of the std blue injectors. I probably took out wrong information out of my inbox.
Does any of you guys run the extracode on their megasquirt?
I will check all my settings and injectors before returning
Yeah i'll stick to the figures as you said. I'm just curious what behind it. I don't only want to fill in all the numbers like this, but also understand everything i do.
Do you guys then also run on TuneStudio instead of MegaTune?
In non of the manuals i see the over and underdwell protection back. I think i'm gonna leave it off as i don't know what is behind it and i know what i'm doing with the dwell settings (i only didn't know the exact numbers for the zetec coilpack and didn't want to start with oscilo)
![](http://s4.postimage.org/xecazganh/ignition_page.jpg)
No worries ![Grin](https://passionford.com/forum/images/smilies/icon_smile.gif)
Fixed advance: Fix advance to X deg or use the ignition advance table
Use Prediction: The code can 'predict' between trigger events, if the engine speed accelerates between trigger events (teeth on your crank wheel) the code can predict where on the ignition table it should be looking (to a certain degree).
Cranking Dwell: The time the coil is aloud to charge when the car is cranking
Dwell Type: Standard uses your settings, fixed is used with external ignition modules such as EDIS which controls coil dwell independently of the ecu.
Maximum Dwell Duration: This is the maximum amount of time in and condition (other than cranking) that the coil is aloud to charge. Excessive dwell time saturates the coil, once the coil is saturated any extra energy input is converted to heat (bad for the coil).
Maximum spark duration: this is the amount of time ms2 code tries to wait before charging the ignition coil after an ignition even. Code aims to achieve the full dwell time + the max spark duration between ignition events. If it cannot use full dwell time AND max spark duration (usually because RPM is too high and the time between events is very short less than 5-6ms) code will reduce each value proportionally until it can.
So if max spark duration is excessive, then dwell time will be reduced. Reducing dwell time reduces spark intensity and is clearly BAD![Grin](https://passionford.com/forum/images/smilies/icon_smile.gif)
A 'spark' even is ended when either the coil runs out of energy OR a new dwell (charging) event begins.
I haven't used spark hardware latency (although this can be setup using a strobe light and setting the timing to a fixed value, rev the engine and see if the timing remains at the fixed value).
I also don't use over or under dwell protection, however it may be a good idea to use over dwell protection as this will stop you from frying your coil, although this has never happened to me.
Hope that helps you
Rob,
Hope that helps you
Rob,
So lets say that Max Spark duration is created to not let the new charging event start while fire'ing. I just found that it just cuts your spark and the new event starts from lil higher amps then 0
The part of hardware latency i understood, but for my start up running without will be fine. The thing i also ment is that i can't find, in the manual, which feedback path the controller uses to create these dwell protections?
If i understand correct the ecu will try to go to max dwell time during all cases. Unless rpm gets too high and there isn't enough time then it will shorten. I know if you set dwell too low it will create misfire during high load. Too high fries the coil. But i can't see where the feedback path is from the coil amps back to the controller. This would be needed for dwell protection isn't it?
Rob,
What i mean is that the code will time how long it is held low yea, but where is this protection based on? Not on maximum dwell time else you can still frie it.
If i set a dwell of 20ms it is clear there will be lots of heat and i guess damage too. With dwell protection what does the processor do. It can't see the heat in my circuit. It can't see the amps over the coil. For protection there is a loop back needed to the controller. Which i'm not aware there is and if it has not got what is the dwell protection based on. Maybe it's a good question for the extracode forum![Grin](https://passionford.com/forum/images/smilies/icon_smile.gif)
Hope my idea/question is clear. Sorry but being Dutch is hard to have this tech english language skills to explain it clear haha
vdun01
Ford Fiesta
05-10-2017 08:14 AM
Matt Baxter
16-09-2015 08:30 PM
default, duration, dwell, efi, escort, maximum, megasquirt, ms2, overdwell, protection, rs, settings, spark, turbo, underdwell
