ARP Con Rod Bolts
ARP Con Rod Bolts
Hello all,
My friend has purchased these bolts for his CVH but the muppet has lost the instructions.
From memory when i built my engine there was a 3 stage torque setting but i cant seem to find what torque they need to go too.
Can Anybody help...?
Tiller
Tiller
hi, just fitted these to my s2 the settings are as follows;
use grease on the threads
stage 1 23nm
stage 2 losen then retorque to 23nm
stage 3 losen then retorque to 23nm
as these are stretch bolts, hope this helps, cheeRS, rob.
stage 1 23nm
The correct torque setting for ARP bolts (8mm) is 34nm. This is with ARP lube applied to the threads. Using regular oil as a thread lube I would use at least 40nm.
ARP bolts are NOT stretch bolts.
Using 23nm torque figure is just a ticking time bomb - Don't do it!
they are stretch bolts, and 23nm torque, i have arp instructions, if you over tighten you will trash the bearings as many have before, best thing to do would ring arp to be on the safe side, like i said i rebuilt my engine with them and went off the instructions with no problems at all. cheers, rob.
For a start which version are they? For standard rods or for aftermarket as there are two types for the CVH.
If they are for standard rods then its 22lb/ft with ARP lube
Non-standard rod type are 45 ft lbs with ARP lube. 65 ft lbs with oil (30w).
Haz87 is correct!
22lb/ft is not the same as 23nm.
23nm is only 17 lb/ft not enough.
RSturbo1991 is providing incorrect figures. nm is not = lb/ft
As per Canada! Not something you want to torque incorrectly so even when torquing up make sure you have set your wrench to the right format (lb/ft or nm - your choice but they are not the same value)
07-10-2015 12:56 PM
DavidK
27-09-2015 02:55 PM
