revs drop and voltage
Hi all im after a bit of help ive got a volts gauge fitted in my rs when sitting there with nothing on all is fine until i put something on like music, lights, fans, heater you get the idea then volts drop to 12v an revs drop off it has new battery an alternator so any other ideas cheers
[QUOTE=rs2kbaby;6154278]check for a bad earth, does it go to stall when driving if you have lights,stereo,e.t.c ?[/QUOTE
It does'nt stall but revs drop right down when i come to stop
umm does sound like an earthing prob, would check and clean earthing points first and go from there, could possibly be the wrong alternator and it isnt sticking enough charge out to keep battery topped up, check see what the ampage should be then look on the alternator to see what its rating is,
curse of the blue wire? check battery voltage before starting and when idling [alternator should be 70 amp ]voltage should rise iffy alternator i think
sounds like a wanky alternator take it back, it has been known for new parts to be faulty especially recon units. possibly might be able to replace the brushes in the unit sounds like they aint making contact until you give it a blap of throttle or the regulator is duff in it, either way i think you have discovered your problem.
i have voltmeter. yes i must admit it is earthed off the cd player but i know it doesnt charge sometimes till i rev it because my power steering dont kick in till its fully charging
dont supose u have a painted or powdercoated alternator bracket?????
when i rebuilt my series 1 i had chargeing issues & it was cos the alternator wouldnt earth to the block cos the bracket was powdercoated. (earth alternator to battery with a jump lead to test)
u checked its charging?????
