what cam for mfi erst s2
turbo-herman
what cam is best to use on a escort rs turbo s2 running on mfi.
Other spec's will be:
stage 2 turbo with -31 actuator
ported and pollished head
rs500 style airtech ic
s/s exhaust
pipercross open air filter
evo chipped ecu.
I know that there was a big hype on newman cams.
Are they still the best choise to make?
regards
s/s exhaust
evo chipped ecu.
regards
Piper 285 t2 cam kit mate reliable unlike the horror story i had with a kent cvh 34 kit which fell to bits on jamsports rollers used the piper kit was a noticeable power gain and the way the car felt
but what ever you get pal some one will all ways have a bad word to say about it as ive learnt on the forum,s
Bet you ANY money I build more engines in any given year than jamsport. So if I know jackshit about engines, how little do jamsport know?
I'm speaking from personal experience, my personal experience tells me Kent and piper are fine.
Balls Deep!
Cam choice is limited really to only Newman these days, as already mentioned Kent and Piper use poor quality blanks for theirs (Not their fault, just all that's available when CVH cam demand is so low compared to other engines).
But as your target BHP is only 250 If your Ford cam is in good condition then just use that it has a very balanced profile.
This isnt just one fella's word this comes from peoples experiances pictures etc and seeing the states of the cams myself with my own eyes but as i have just said all these fellas are obviously lying and i dont know anything i have only had 24 rst's what would i know
in the garage
Mines had a piper 285 t2 in it since early 2005 and that seems fine its even survived an oil pump failure (car was only idling for 10 seconds max when I noticed the oil pressure gauge had dropped so I turned it off) must be a lucky one I have.
An eye for detail...
MUCH better than previous engine which had a Piper 285T2.
Solid followers are a bit of a pain, but an hour or so every year/10k miles is a small price to pay.
Spec is similar to mine except for port and polish, i just did inlet matching when i rebuilt it.
Got a VERY good deal from Newman too, and very helpful over the phone with some problems i had with previous engine before id even mentioned buying a kit from them.
Balls Deep!
No, it's fine IME and I don't see why the way the fuel is injected (electronically or mechanically) has any bearing on how much air is allowed to flow into the engine as long as it is matched by the correct amount of fuel.
Mc5506
05-10-2015 09:57 PM
