steering ratio
steering ratio
hy i have on my rst2 -35mm lower team dynamics pro race 3 17 ET 38 wheels
with 20mm spacer every thing is nice but if i turn it full on the left side or right side the inner of the tyres touch the shell
i want to know how can i do when i turn the steering wheel that it stop earlyer to don t have so a big rotation can i change something in the rack ?
thanks
thanks
You need to keep the ratio the same as standard, what you need to do is put limits inside the rack. When you remove it and take off the bellows you should be able to put stops on the rack gear.
07-10-2015 12:56 PM
dange
Ford Mondeo Including ST
23-09-2015 12:11 PM
