Water pump with plastic impeller?
My Cossie Ate My Money
My new water pump arrived today for my CVH build and the impeller is plastic, will this be ok the old one was steel?
Ask me a question!
its not the material you need to be that worried about as i havent seen any cvh water pumps that have issues with plastic parts.
What you should take note of is if the fins have a hole to allow better water flow. Most plastic ones do not have a hole as per the factory unit and will not cool as well as the type with a hole.
Probably unlikely, but if the coolant ever freezes a plastic impeller will just break rather than shredding the teeth off the cambelt when the engines turned over.....
Mark RS
12-10-2015 06:01 AM
