Turbo difference
Old Dec 5, 2012 | 08:59 PM
TomPengelly's Avatar
TomPengelly
Kapow!!
Default Turbo difference
How do i tell the difference between a T2 and a T3 turbo? And can i use a T2 or are they not as good?
Old Dec 5, 2012 | 09:01 PM
crazycage's Avatar
crazycage
what turbo?
Old Dec 5, 2012 | 09:05 PM
TomPengelly
Kapow!!
I bought a 90 spec series 2 the other day. Head gasket went so i pulled the head off, while it was off i checked the turbo and there was loads of play in the shaft. I was told it was a standard T3.
Someone has given me another turbo to try but he thinks its a T2 from a series 2...
Was just going to use it for now untill i get the original one rebuilt...
Old Dec 5, 2012 | 09:12 PM
studabear's Avatar
studabear
t2 was from the fiesta rs turbo, afaik won't fit a erst manifold to start with
Old Dec 6, 2012 | 08:07 AM
TomPengelly
Kapow!!
So if it fits on my manifold should it be ok to use?
Old Dec 6, 2012 | 03:08 PM
gpm89's Avatar
gpm89
Also it is normal for there to be side to side movement on the turbine shaft. Its the end float that causes problems
Old Dec 6, 2012 | 05:46 PM
danielson04's Avatar
danielson04
I wouldn't bother fitting it mate, t2s are basically downgrading. U tend to use the t3s on fiestas as a upgrade.. For how much it costs,your proberly best to get the one on it recon'd.
Old Dec 7, 2012 | 10:07 AM
Rogeyboy's Avatar
Rogeyboy
It wont be a T2... S2s used the same turbos as S1s albeit with water cooling.
If it looks the same and is on the same manifold its a t3 and it'll fit
Old Dec 7, 2012 | 10:24 AM
Karlos G's Avatar
Karlos G
Balls Deep!
The T2 is tiny and looks obviously different to the T3, you'll know if you have one! lol
Old Dec 7, 2012 | 11:46 AM
v man's Avatar
v man
Zee Germans are coming
Google fiesta t2 turbo charger and then escort rs turbo t3 turbo charger and you will learn the difference
Matt Baxter
Sep 16, 2015 08:30 PM
muz
Aug 16, 2015 12:57 PM
A.t.p
Aug 15, 2015 11:37 AM
Michael Wisbey
Aug 14, 2015 11:57 PM
Hellraiser
Aug 8, 2015 04:19 PM
