Help Needed!!!!!!!!!!
Old Apr 25, 2004 | 07:51 PM
m_nettleship's Avatar
m_nettleship
Default Help Needed!!!!!!!!!!
When my rst turbo is ticking over it, revs to 2000 then back down to 1000 then bk again and so on. all new gaskets inlets and throttle body.it also hesitates when it gets to 4000 revs but once its through that its ok. Any ideas well apprecaited.
Old Apr 26, 2004 | 04:57 PM
RS RUDEBOY's Avatar
RS RUDEBOY
i had the exact same problem on my s2, i had a fcuked actuator and my lower boost hose that goes from the induction kit to the turbo was collapsing unser boost so i put a set of samcos on and a new actuator then had it set up and now it runs sweet as a nut! get it inot the tuners mate , its probably the fueling as mine was using 30% more than it shouldve been!
Old Apr 26, 2004 | 06:17 PM
m_nettleship
can u tell its that by looking and feeling at the hose???? the hesitating seems to be in 5 gear only.
Old Apr 26, 2004 | 06:20 PM
RS RUDEBOY's Avatar
RS RUDEBOY
if its a stnadard hose it usualy feels really soft, the oil corrodes the insides of the hose! mine wouldnt boost right and hesitated if i put my foot to the floor , to get it to run right i had to ease the accelerator down slowly
Old Apr 27, 2004 | 07:17 PM
m_nettleship
changed the hose and hesitating still the same but a tuner can sort that out its the ticking over thats the real prob. soon as the cold start stops in up to 2000 then 1000 and so on.
Old Jun 16, 2004 | 02:24 PM
KSA-Cossie's Avatar
KSA-Cossie
did you ever get your idle fixed m8 ?
Old Jun 17, 2004 | 01:00 PM
jodyhoare's Avatar
jodyhoare
is it fixed?? if not it is prob the idle screw at the end of or throttle cable i had the same prob!
JoeyBoyden
Jan 4, 2024 02:36 PM
jessie_rs
11
Jun 3, 2019 04:57 PM
borboyous
Aug 22, 2015 11:17 AM
col93saphcos
Aug 7, 2015 03:21 PM
