FAO IB5 converts. Update
I had a thread going on this somewhere but can't find it. I think Rogey was asking what I went for in the end?! not sure... anyway..
It looks like I will finally have my IB5 gearbox finished next week.
In the end I went for Ka 1.3 gearset and a 1.7 puma Final Drive (3.82) Which should give me as close as possible std RST ratios:
-Ka 3.15 1.93 1.28 0.95 0.76, FD 3.52
-RST 3.15 1.91 1.28 0.95 0.76, FD 3.82
Still not 100% on this though as it turns out nearly every forum I've looked on has different info. Especially when it came to the ka 1.3 final drives.
I'm using the bellhousing from a mk5 diesel for the cable clutch operation, and the main box housing from the Ka 1.3 as this will allow me to use the BC reverse switch mechanism so I don't have to faf around changing the plugs etc..
UPDATE: On closer inspection I cannot use the Puma final drive. It has much larger width teeth with matching pinion, however, the diff is 2mm smaller diameter than the ERST slip diff so it wont bolt to the crown wheel. So I will end up having to use the KA 3.58 FD
Spanner monkey
Was thinking of using the complete KA box including the hydraulic clutch on my fiesta rst track car
Balls Deep!
1.3 Ka's are supposed to have either 3.59 or 4.06 depending if they have PAS or not, but all the ones I've had have been 3.59 (I always count the teeth and calculate the FD to check before fitting) which is spot on, not too long and not too short, couldnt tell the difference between that and a stock RST box.
Balls Deep!
As above they are cheap as chips too, I pay no more than Ł35 a box and drop an LSD in, job done!
![](https://passionford.com/forum/images/smilies/roi.gif)
I broke a couple of ib5s in my puma engined fiesta.
Both cracked around the diff area and shit the diff out. One out the top of the box, and one cracked and went inside the bell housing, fucked the clutch aswell that time.
One I broke launching it, and the other sort of locked up on a hard 2nd gear corner.
TPM961
15-01-2018 10:50 AM
