Radiator problems Again
Old Sep 19, 2012 | 06:40 PM
Mids_s2's Avatar
Mids_s2
Default Radiator problems Again
hi does anyone know of any other ford model or any make that I could use on my s2 radiator? I have a front mount so have to have room for pipe up the side.
Thanks Ben
Old Sep 21, 2012 | 08:30 PM
mk1trb's Avatar
mk1trb
Boost Junkie
none that fir straight in mate, xr3i is too wide, fiesta turbo is smaller and missing the tabs to hold it in, xr2 is the closest but again missing the top post to hold it in place
Old Sep 21, 2012 | 10:04 PM
studabear's Avatar
studabear
I've seen a honda civic rad plumbed into my mates zt cabrio
Old Sep 21, 2012 | 11:07 PM
blue oval 24v's Avatar
blue oval 24v
get an alloy rad made one off the best thing's you will do
Old Sep 21, 2012 | 11:10 PM
Stolton's Avatar
Stolton
What problems do you keep having mate? A alloy rad is def the best way to go tho..
Old Sep 22, 2012 | 12:28 AM
botters's Avatar
botters
competant bodger
not always true alloy is not as good a heat conducter as copper airflow is key
Old Sep 22, 2012 | 05:30 PM
Rogeyboy's Avatar
Rogeyboy
Aluminium has near as dammit the same heat conductive properties as copper, esp as most standard rads dont contain much copper anyway! Look how many things in life use aluminium as a heat sink, PCs, Lights, TVs etc etc.
Aluminium rads also usually have alloy end tanks rather than plastic... Also the fins on an ally rad, are alloy and welded to the core so no loss of heat transfer, whereas copper rads have steel or copper fins that are soldered onto the core, solder doesnt conduct heat very well at all...
DAZZER
Sep 30, 2015 08:43 PM
