engine problems
Old Sep 6, 2012 | 09:43 AM
jonesy1381's Avatar
jonesy1381
Default engine problems
was driving along & everyhing was running fine but then it started to pop & bang & hasnt ran rite since..can anyone shed any light plz
Old Sep 6, 2012 | 02:06 PM
mgtkr1's Avatar
mgtkr1
check leads ect and all connectors. starting will hall sensor on dizzy. i had the same problem and it turned out be si;icon spray, i had sprayed had gone thin in the heat and made it onto the contacts/terminals. give it a wipe/spray with contact cleaner and then id be looking at a new dizzy. hall sensor is integral with the dizzy unfortunatly. you may be lucky though.is the tps working ok?
Old Sep 6, 2012 | 02:07 PM
mgtkr1's Avatar
mgtkr1
btw what boost are you running and when were your plugs changed last? plugs dont last long with higher boost levels.
Old Sep 6, 2012 | 03:05 PM
jonesy1381's Avatar
jonesy1381
im not to sure of what boost im running but the plugs are new,new coil & leads & dizzy cap..
Old Sep 6, 2012 | 07:07 PM
paul-h's Avatar
paul-h
Check for a boost hose off, I imagine you have but just make sure! That's what happened when I popped a hose off.
It will most likely be something stupid!
Old Sep 6, 2012 | 07:52 PM
S2gogs's Avatar
S2gogs
Sounds like the distributor 2 me. Same symptoms as when mines packed in.
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
da52rkn
Ford Focus Range
Aug 21, 2015 04:41 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Zoggon
Aug 10, 2015 10:39 AM
Blown Hell
Aug 5, 2015 07:22 AM
