wat mods on 2.1 zvh to get 300 -350 bhp?
There are many "stage3" heads sold that are crap. Just because someone took a grinder to the ports and fitted larger valves does not mean it will be good for 300 HP. Most likely it will be worse than a factory un-modified head.
Unless the stage 3 head had been done by a very reputable shop do not buy it.
The stage 3 T3 will not make 300 HP - maybe 270 flywheel HP at most.
Anyone that says their stage 3 T3 is making 300 HP is not being honest.
PUG 306 GTI-6
In my opinion, decent management, newman cam, gt28 if money permits or t34 turbo ported and polished head done by someone reputable as canada says, good set of injectors, decent fuel pump, grs or new airtec cooler good gearbox to handle the torque level a zvh produces good set of breaks to stop the bloody thing lol
i need some guidence lol, im running now
1600 cvh fiesta efi
lightened and balanced bottom end
forged pistons and steel rods
stage 3 head
t3 hybrid not sure what stage
-31 actuator
full front mount
alloy rad
samcos all round
lsd cvh rst box
beiges 701
bayjoo chip on OFAB
running 205.7 bhp and 186.9 lbs ft
i have ready a 2.1 zvh with all oil ways done water pump n sump ect, mondeo rods (ill need some steel rods???)
no crank?? which to use
escort cosworth forged pistons
an mfi head with bigger valves (no cam or pully)
OFAM ecu
never built an engine really so stuck, and what bits can i scavage off my efi??
what gearbox should i use (what car can i get one from)
clutch, flywheel??
cheers
1600 cvh fiesta efi
stage 3 head
-31 actuator
full front mount
alloy rad
samcos all round
lsd cvh rst box
beiges 701
bayjoo chip on OFAB
OFAM ecu
clutch, flywheel??
cheers
does it go straight on no mods because of cvh conversion?
cheers
1600 cvh fiesta efi
stage 3 head
-31 actuator
full front mount
alloy rad
samcos all round
lsd cvh rst box
beiges 701
bayjoo chip on OFAB
OFAM ecu
clutch, flywheel??
cheers
1600 cvh fiesta efi
stage 3 head
-31 actuator
full front mount
alloy rad
samcos all round
lsd cvh rst box
beiges 701
bayjoo chip on OFAB
OFAM ecu
clutch, flywheel??
cheers
My brother has got a 2.1zvh with 330bhp
Cosworth racing pistons
PEC steel rods
Arp bolts
Cyilinder head developments stage 3 big valve head
Solid lifters
Sitech spec newmans cam
Turbo Technics T38
Cosworth sweedish plenium
Haltech management
Stage 2 cts gearbox
PEC steel rods
Arp bolts
Solid lifters
Turbo Technics T38
Haltech management
Stage 2 cts gearbox
1600 cvh fiesta efi
stage 3 head
-31 actuator
full front mount
alloy rad
samcos all round
lsd cvh rst box
beiges 701
bayjoo chip on OFAB
OFAM ecu
clutch, flywheel??
cheers
1600 cvh fiesta efi
stage 3 head
-31 actuator
full front mount
alloy rad
samcos all round
lsd cvh rst box
beiges 701
bayjoo chip on OFAB
OFAM ecu
clutch, flywheel??
cheers
If they're in the block then they are not Escort Cosworth pistons! They're about 10mm bigger in diameter from memory!!
If you have a steel CVH already and a big port head just get a cam, bigger turbo, bigger injectors and get it remapped with some decent boost. Your CVH should put out 300 easily enough.
No point in spending loads of money if you already have the engine to make the power in the car.
SMILER258
28-09-2015 09:04 AM
