whats the limit for a BC box
ive run 3330bhp through standard 1 and didnt break , changed to big bearing box and went straight away its luck of the draw with them really , i have broke 1 at 180 bhp in a different car also
What cam where you running for the 3330 bhp run Stu ?
Mines just shat its pants at about 180 bhp without any hard driving!!
Wye Valley Hardcore
I don't think S1 boxes are any stronger, you just got lucky with it. I think I'm right in saying the BC box is a standard spec 4 speed box with a 5th gear banged on the end, and as such, is built to handle low power. The BC box is inherently weak due to having a flexible casing which destroys the bearings under load. Also, main shafts have a habit of snapping, gears sheer teeth. They aren't built for big power.
they're chocolate mate. blew 4 in 18month at 150bhp in my old s2. main shaft every time. crap boxes. had upgraded bearings machine in to try prolong the inevitable . next time mtx is going in.
Balls Deep!
IB5 is the best you can do for very little money.
If it's being claimed it's done XXX launches and trackdays, it's bollocks.
I've spoke to people who have made big claims of having boxes in for a long time, but the actual amount of work/abuse it has done is minimal. You can run a weak gearbox for years if the car is just sat about and polished.
Ive known so many people blowing these boxes up but mine has been fine since ive owned it but do feel it might need a rebuild soonish. It ran at least 40kmiles on 172bhp with 184ish torque before i owned it. Since then its been running just over 200bhp with around 215ish torque for nearly 60k.
People get so caught up in the power when it's the torque that kills boxes. As somebody said on a limited budget the best you can do is an IB5 with the LSD dropped in.
My 260bhp, 250lb/ft S2 has had a CTS box in for years now and prior to being laid up was used on track and hammered at Brunters and Santa Pod.
Steve Escos
01-10-2015 06:57 AM
SMILER258
28-09-2015 09:04 AM
Russ Payne
25-09-2015 08:29 PM
