engine noise! almost given up
21-07-2012, 06:07 PM
Quote:
Originally Posted by
B16CVH
Not the piston hitting the valves maybe if the heads have been heavily skimmed/block heavily decked?
did think this so changed for a different head and no difference. how would the driveshafts be noisey also??
21-07-2012, 06:15 PM
If the block has been heavily decked changing heads won't help. This would not be linked to any drive shaft issue.
21-07-2012, 07:16 PM
B16CVH
i noticed that the pistons slightly pretude the bores, but was told this was normal.
21-07-2012, 07:28 PM
Yes that is right, they do protrude, even more so if it's been decked taking them closer to the valves
21-07-2012, 09:03 PM
could it be bad alternator bearings? or ps pump??? worn bearings make a lot of noise so.... probably not but i guess it s worth taking their belts off for a try???
21-07-2012, 09:09 PM
landaqmabba
doesnt have power steering. could be the alternator il whip the belt off and give it a go.
21-07-2012, 11:01 PM
Any chance of a vid? Trying to diagnose this blind will be pretty tricky.
22-07-2012, 07:56 AM
Rob_DOHC
Il try get one up dude.
22-07-2012, 08:05 AM
why not just whip the head off and change the cam? seems you know what your doing in fitting new parts so i doubt the bottom end has spun a shell
22-07-2012, 08:38 AM
boy-racer-1
You don't need to take the head off to change a cam on a cvh
22-07-2012, 09:25 AM
cams are service items on a tuned rs turbo, bad design from the factory and no decent material to use for blanks.
newman are the best or a genuine ford cam !kit!
22-07-2012, 09:37 AM
boy-racer-1
bottom end has deffo not spun a bearing as already had the sump off and changed the big ends and mains again since rebuild. yes i have a cam on the way so should be fitted on tuesday.
22-07-2012, 09:47 AM
When you changed the cam and pulled the rockers off was the little shim still on the head where the rockers sit on
22-07-2012, 09:50 AM
yeah they were dude.
22-07-2012, 09:58 AM
Does the noise change when you put your foot on the cutch
Might be a silly one but have you pulled the leads off one by one to see if you can trace it to one cylinder
22-07-2012, 10:01 AM
no noise doesnt change when you press clutch. you cant hear it on tick over just when you drive it.
22-07-2012, 10:06 AM
My cvh sounds like a skeleton having a wank in a biscuit tin at idle, when it gets nice and hot it gets a lot quieter.
My solution is to ignore it and replace it with a zetec
22-07-2012, 10:26 AM
studabear
22-07-2012, 12:12 PM
studabear
lol nice description. il get the cam in and go from there
22-07-2012, 01:39 PM
studabear
lol, I'll remember that one.
Rob,
30-07-2012, 08:07 PM
well had the car looked at today and the result is not good. the engine has major piston slap, gutted as the bores ect got measured but clearly not right! dont know what to do now. considering selling the car as im moving abroad in november. any interest?
30-07-2012, 08:24 PM
Did you have the block bored with new pistons/rings?
30-07-2012, 08:37 PM
B16CVH
block was already at .5 oversise so was honed and checked for wear. new rings were fitted. dont know what my options are now apart from a new block
30-07-2012, 08:43 PM
U can get 1mm and 1.5mm o/s accralites but then more cost:-(
30-07-2012, 08:55 PM
B16CVH
yeah your right means buying new pistons ect ect.
30-07-2012, 09:07 PM
Should be easy enough to pick a decent block up, then get a decent machine shop to sort it out? I've got a block but I'm a bit far away.
malkiemac3579
14-07-2017 12:10 PM
bigryrs
Fiesta RS1800/RS Turbo
14
21-01-2016 09:54 PM
Churtz
15
13-08-2015 06:40 PM
track.focus'd
12-08-2015 05:53 PM
jimmy oldskool
Ford Focus (All Models)
04-08-2015 07:06 AM
bottom ,
cvh ,
end ,
escort ,
foesta ,
ford ,
hear ,
high ,
knocking ,
load ,
motor ,
oil ,
rattle ,
rebuilt ,
rpm ,
rs ,
starvation
