Headlight problem?!?!
Old Apr 19, 2004 | 08:43 AM
JamesS2RST's Avatar
JamesS2RST
Default Headlight problem?!?!
Hi,
Got a slight problem with the headlights on my S2 RST.
Dipped work fine, but when you put them on main beam, they are DIMMER than when on dipped, and full beam is only about the same as main beam, still with me?!
This happened whilst driving home the other night, they went dimmer or even off totally on there own then went back to normal again a few seconds later, this got worse the next night with everyone thinking I was flashing them!!
Any ideas?
Cheers,
James.
Old Apr 19, 2004 | 08:48 PM
Rick's Avatar
Rick
what the hell does that mean?! Full Beam and Main beam are the same think!
Old Apr 20, 2004 | 07:28 AM
JamesS2RST's Avatar
JamesS2RST
It means they are the same on full beam as they are on main beam! Full beam as in what you would flash someone with, main beam ie. normal driving/night conditions! Or am I wrong? Either way, they are knacked, so any help would be much appreciated.
Cheers,
James.
Old Apr 20, 2004 | 09:22 AM
Rick's Avatar
Rick
No! Main beam and full beam are the same! Normal driving are called dipped beam!
Old Apr 20, 2004 | 10:05 AM
DanS2turbo's Avatar
DanS2turbo
?? does it matter?
Old Apr 20, 2004 | 03:17 PM
adamS2RST's Avatar
adamS2RST
Sounds like a smiliar prob I had with my old S2. the alternator was fucked, and having my full beam on at night and stereo made it all die and I had literally no lights for a few miles in pitch black, fuck that is scary! it even dimmed my clocks right out! it was like the batt wernt getting enough chrge, but when i booted it, it all popped back into life, anyway changed the alternator and that sorted it.
You might wanna change your batt as well, could have drained that a goodun.
Old Apr 20, 2004 | 05:01 PM
Had a prob with mine you would be driving along with headlights on and they would start to flicker on and off some times go off an not come back on.found out it was the brown relay in top right corner of fuse box,it had melted and didnt have a good conection any more.change the relay an make sure the conections in fuse box are ok .(not to far apart) hope its some help
Old Apr 20, 2004 | 05:11 PM
chewyS2RST's Avatar
chewyS2RST
got exactly the same problem on mine,not that its on the road at the mo.
The problem is the fuse box,there are 2 white relays in the box that control
the headlights mine have over heated and made bad connections inside
the fuse box i changed the relays twice and its fixs the problem for a
month or so then it starts messing about again.
Ive yet to fix the fuse box so i cant give you any idea on cost.
Hope thats some help.
Old Apr 21, 2004 | 08:02 AM
JamesS2RST's Avatar
JamesS2RST
Nice one, cheers for that!
I'll have a look in the fusebox then, and let u know how I get on, hope I can get it sorted, just one of those annoying niggly problems!
Cheers,
James.
Old Apr 29, 2004 | 11:26 AM
Rick's Avatar
Rick
common fault - best way is a new relay box and new wiring.
DAZZER
Sep 30, 2015 08:43 PM
mondeomark
Sep 28, 2015 06:28 AM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
