Sender question!!
Old Dec 10, 2011 | 09:56 AM
blackbeautyzetec's Avatar
blackbeautyzetec
Default Sender question!!
Can I use a 90 spec on a 88?
Are they different?
Does it matter??
Please help
Old Dec 10, 2011 | 12:32 PM
Rob_DOHC's Avatar
Rob_DOHC
Sorry mate, is this the fuel sender? or a temp sensor etc? in either case you should be fine, although i have a feeling ford changed the connector on the fuel sender unit at some point (but can't confirm this).
Rob,
Old Dec 10, 2011 | 06:38 PM
blackbeautyzetec
Yea fuel sender and I also now been told they are different apparently
Old Dec 10, 2011 | 09:01 PM
dangerousbrian's Avatar
dangerousbrian
ideally you will need to check the hole in the fuel tank where it fits in. there are two different sizes and the difference is quite big
Old Dec 10, 2011 | 09:48 PM
blackbeautyzetec
Yea I understand that but that means buying 2 or pulling it apart to see what one and then getting one
Old Dec 10, 2011 | 10:53 PM
Rob_DOHC's Avatar
Rob_DOHC
Hmmmm I didn't know the hole was a different size, What year is yours? Mines 88spec and was roughly 5 inches diameter (from memory) when I had it apart.
Old Dec 11, 2011 | 10:13 AM
dangerousbrian
ah sorry , i was of the understanding that it relates to if its mfi or efi. i thought rs turbos were all the same andonly changed for xr3i and orion, but could be wrong
Old Dec 11, 2011 | 10:39 AM
phil_rs's Avatar
phil_rs
yam yammer
There are definitely 2 sizes.... pre 89 has the larger sender and post 89 has a smaller one.
Old Dec 11, 2011 | 10:49 AM
RSandy's Avatar
RSandy
yup, phil is bang on the money, the 90spec fuel sender is tiny compared to the pre 89 sender! i stupidly bought a replacement sender for my 88 tank, and bought an 90spec sender, and it is less than half the size, just falls straight thru
also im sure i got told back at the time that u needed the correct spec clocks to match the sender? cant find the old thread, but im sure thats what i was told by numerous people
Old Dec 11, 2011 | 11:05 AM
blackbeautyzetec
Na can't need the same clocks, really? Loom maybe different to connect
Old Dec 11, 2011 | 11:17 AM
RSandy's Avatar
RSandy
just what i was told, is it the later clocks have the fuel n water temp gauges swapped round?
it may be wrong, but it came up when i asked a similar question on here, like 5 years ago, so i figured just buy the clocks i was told just to be safe lol
Old Dec 11, 2011 | 01:50 PM
blackbeautyzetec
True say! Always the best way
Old Dec 11, 2011 | 01:59 PM
phil_rs's Avatar
phil_rs
yam yammer
Andy is correct! Pre 89 clocks have the fuel gauge on the right and will only work with the larger sender and post 89 clocks have the fuel gauge on the left and will only work with the smaller sender
Old Dec 11, 2011 | 05:04 PM
RSandy's Avatar
RSandy
knew i wasnt mental!
well, i am, but in this case i just knew i wasnt lol
Old Dec 11, 2011 | 06:57 PM
blackbeautyzetec
Has anyone got the bigger laying around? Or can a person post in the want part?
Thanks
Old Dec 18, 2011 | 12:10 AM
blackbeautyzetec
Well changed it over. Was the bigger one like I thought.... But wow the one in the tank was mangled... Weird
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
Iain Mac
Sep 30, 2015 09:39 PM
stevecfrst1
Sep 30, 2015 05:18 AM
